How Do You Clean Your Car?
so whatever the amount of dust it will clean in one go or there is any specific way to clean with it
Just swiping it over the whole body will finish your job and very quick indeed, make sure you don't swipe when there is water and mud in the body. The purpose of the duster is to take away all the loose dust only.
PUNE
As suggested please, use these dusters very gently on the car paint or you will induce swirls over the period of time. Please, don't use it on heavily dusted car.
Sharing a good video on how to use these dusters properly on the car paint -
https://www.youtube.com/watch?v=8gVU4C_6wOE
palwal
I am really frustated i cant clean my windshield again and again watermark crease please guide
Have you tried any glass cleaner like Meguiar's Glass Cleaner? Although a bit costly but you can dilute the solution and it works perfectly.
i have mga kit its shampoo doesnt make foam. glass cleaner doesn't not do anything. And can i use mf cloth for windshield or not?
PUNE
I haven't used there shampoo but i am using there glass cleaner in diluted solution and no issue.Yes you can use good MF cloth on it.
PUNE
You can also use B&W newspaper to clean and dry the glass after wash but i found good MF cloth better.
I am using Autofresh - Glass Cleaning Microfiber cloth.3M all purpose MF cloth will work equally well.
palwal
i have mga kit its shampoo doesnt make foam wow glass cleaner doesnt not do anything wow and can i use mf cloth for windshield or not?
actually there were water marks dried after rain. You know what i mean. then now i throw some mist of water on the shields and wiped with mf but all white crease all over. Wait, there do i have to dilute the cleaner first?
PUNE
actually there were water marks dired after rain you know what i mean then now i throw some mist of water on the shields and wiped with mf but all white crease all over
Dried water marks will be tough to remove with plain water.It will streak with MF. Use some specialized cleaner or try to wash it with your car wash shampoo and use Black and white newspaper to clean and dry the surface or streak free glass cleaning MF
Tushar,
Just use a MF cloth to clean your glasses. If you dont have cloth, use a newspaper or tossue. Its good to keep a box of tissues in your glove box for removing bird droppings from time to time
On a side note, I did try out the 12v pressure washer to wash my car. Once the o-ring seals that came with the washer were installed, all the leakages were fixed and it has sufficient pressure to clear dried up bird droppings also. Makes life much easier when your washer guy doesnt show up and to clean those troublesome areas like seam lines, wheel arches, badge corners etc where dust tends to accumulate
Ameyam
palwal
do i have to dilute the liquid cleaner with water or not?
Nasik
Holiday detailing :
Today was holiday so planned long waited dashboard cleaning of my Spark LS
1st get inspired by reading detailing forum and reviews of benge color dashboard.
1 st prepared 10MM:500 ML water solution in spray bottle (doubled the ration for hard stain)
with 3 MF walk into car with music.
1st i sprayed raw extreme wait for 10 sec and wipe with mf but no change found.
Again went to home and pickup Mr muscle bottle with childs unused soft tooth brush
spray over dash board gently used tooth brush and wipe off.
Its all gone and dash board looks pretty good.
do rest of all area and dress with motomax dashboard dresser.
