Update :
All the 10 bushes replaced.
The stabilizer bushes , totally 8 . 4 pair also replace . - locally its termed as pattanni bush
After fixing all the rods , phew damn heavy job , only at the last found that we have interchanged some bolts. oh not again remove all and refix everything. a whole day gone.
almost at the end , the stabliser rod holder bush was over size and need some cut and fix. on hammering the clamp of it , it broke ! and finally on 2hrs searching just one shop had one and bought that.
clamp - 120/-
coil spring pad - 200/- each . got two of them
Lather charges 250/-
Today hope the beast will be back on the road.
And the important thing about the 16incher tyre. it just scraps here and there on load.
earlier i have mentioned that it doesn't scrap. may be due to worn out tyre. .also signs of mudflap bolts being filed to even are found - meaning previous tyre have scrapped them and have worn out them??
today will carry out some of the welding work required to remove them and also the foot step need to be cut to some extent. works fine in road , but when jacked up , the tyres scraps them.
