DIYs Done On My 2017 Hyundai Creta (1.6L CRDi)
Thread Starter #16
Power Window switch illumination
  • Hyundai India conveniently decided to omit the lighting on the individual power window switches making it difficult for users to locate the switch during night times. Thanks to AliExpress, these switches were readily available at a decent price. Without much thought, I went ahead and got three of them.
Power window switches from AliExpress
New vs OEM switch
Door pad removed
The power window connector removed
Using a small flat screwdriver, pry the tabs (marked using the arrows in yellow) to free the switch from the door pad
The power window switch removed
The 5-pin power window switch connector
Test successful
Rear switch installed
Front switch installed
Close-up of the illumination
Small LED bulb for the illumination - matches the interior lighting
  • The point here is, the wiring etc is ready in the car with this feature enabled but Hyundai decided to cheap out on the switches and all it takes is a simple switch change to get this lighting to work. This modification is not going to make any 'real' difference in operation but will address something that should have been there since day 1.
Thread Starter #17
DIY - Puddle Lamps
  • Another cosmetic modification but thanks to the door design, the overall lighting spread wasn't as I wanted.
Puddle lamp - A pair
LED's
Details and dimensions
The hole was drilled in the access cap on the base of the ORVM casing
Puddle lamp mounted on the base cap trim of the ORVM
The screw tightened to hold it in place
The cap refit on the ORVM base
View of the puddle lamp from underneath
Puddle lamp ON showing the throw of the light onto the road below
Close-up of the puddle lamp when the LED is on
  • As seen in the image above, the sharp crease on the door near the ORVM area is blocking most of the light which is not helping matters in lighting up the road below.
  • There is no other location on the ORVM body where I could mount the puddle lamps for better light output but I compromised.
Thread Starter #18
LED Swap - Interior lights (Cabin and Boot)
  • As per the specifications, the interior lights are 31mm in dimension and 'festoon' type. There are 2 bulbs in the front reading light; 1 bulb in the central cabin light (between the front and rear seats) and 1 bulb in the boot. So I placed an order for 10 bulbs from AliExpress since it was cheaper to get.
31mm festoon LED bulb
OE bulb vs LED (31mm festoon)
1. Cabin Light LED swap
Front Reading light
Instructions to open the covers to gain access to the bulbs
Covers removed - OE bulb in the holder
Replaced with the LED bulb and angled it outwards for better light throw
The difference in lighting - OEM vs LED
OEM light output in the cabin
LED light output in the cabin post replacement
2. Boot LED swap
Boot light with OEM festoon bulb in the holder
Replaced with the 31mm festoon LED
LED ON
Light output with the OEM bulb
Light output with the LED bulb - The picture is not doing justice but yes, this was not sufficient as the area to the left of the boot was still in the dark
Thread Starter #19
DIY - Boot Illumination modification
  • To address the dark area in the boot (especially the left side), I added a piece LED strip to evenly lighten the boot. Used the same strip of LED as in the footwell and glove box illumination.
Wiring and insulation tape was purchased for completing this modification
The boot lamp removed from the mount
Soldering two wires on the metal contact point for connecting the LED strip
Two wires soldered on the boot lamp
LED strip stuck on the underside of the parcel tray for effective lighting when the boot lid is opened
Beading opened to route the wires
Used bullet connectors on the parcel tray for connecting the wires. Will help when there is a need to remove the parcel tray from the car without losing the boot light
Wiring from the cabin connected to the parcel tray
LED in action from inside the car when the boot is opened. Also seen to the left is the small OEM boot light
Light output - Before the modification
Light output - After the modification
Another image of the LED strip lighting up the boot. Also seen are the puddle lamps in action
Thread Starter #20
LED Swap - Tail lights + Brake lights
  • Another LED swap has been carried forward from my previous car.
Used this for the parking light located on the boot lid
Used this for main parking + brake light located on the body of the car
Twin tail lights - In the OE setup, the internal ones (located on the boot lid) light up as parking lights only whereas the outer one is for both parking + brake light
Pry open to remove the cover - The location to pry is highlighted using the white arrow
The cover was removed to access the bolts holding the tail light
The boot lid panel was removed to gain access to the bulbs on the inner side
Tail light removed from the body
Sockets and connectors of the lights
Stock halogen bulb
Replaced with LED
Connector and bulb holder for the inner tail light section
OE tail lights + brake pressed
Lights after the LED swap
Swapped the number plate light with LED (T10)
Thread Starter #21
DIY - Dual Brake Light MOD
  • In the Creta, the outer lamp glows brighter when the brake is pressed since it has a dual filament bulb whereas the inner lights are single filaments that glow only when parking lights are turned ON. I wanted all four lights to glow when the brake is pressed.
Got a spare set of the tail light harness from a scrapped Creta to use the pins for the addition of a new wire to connect the two tail lights
The inner section light removed to connect the wire
Tail lamp removed
Wiring harness pins on the couplers
De-pining was done to solder a wire to connect the two tail lamps
Parking lights ON
Brake lights ON - All four lamps turn ON when the brake is pressed
Thread Starter #22
LED Swap - Reverse Light
  • Bulb Type: T16
OE bulb vs LED
Socket for the reverse bulbs (connector with two blue wires)
LED bulb fixed
OE yellow - Light output
LED bulb - Light output
  • After 1 year the LED bulbs started to fail slowly and by then AliExpress was not shipping to India anymore so decided to try something locally so I can procure the replacement easily (if required).
New LED bulbs
Old LED bulbs vs New ones (Better quality and fit)
LED output during the day time post swap
Thread Starter #23
DIY LED Swap - HMSL
  • Another simple LED swap from the OEM yellow bulbs
  • Bulb type - T10
HMSL (High Mount Stop Lamp) - Sits flush with the boot lid. Access to the bulbs is from inside the body of the HMSL
HMSL cover
Using a pry tool or flat screwdriver, pry open at the location pointed in the image below to remove the cover
The cover removed
Three screws exposed that hold the HMSL to the body of the boot lid
Remove the washer fluid pipe and remove the HMSL from the body to gain access to the individual bulbs
OEM T10 vs LED bulb
Difference in lighting - OE vs LED
All 4 bulbs replaced with LED
Thread Starter #24
LED Swap - Indicators
  • Since it was a solo DIY, I couldn't click detailed images of this DIY. The flasher circuit in the Creta has the relay embedded in the BCM so replacing it was not possible. The only way I could add an LED bulb with the issue of 'hyper-flashing' was by adding a resistor in between. I procured 4 resistors with scotch lock connectors for this modification.
  • These bulbs were carried forward from my old car (Swift ZDi).
Resistors used with the scotch lock connectors
OEM bulb vs LED bulb
  • Since the resistors get hot when the LEDs work, they had to be mounted on a metal surface strictly to avoid any issues. I chose safe locations that wouldn't be an issue when the resistors get hot.
  • Will add the video link here after I upload it on YouTube.
Thread Starter #25
Rear Reflectors - LED Swap
What I paid
Pair of reflectors
Wiring to be connected to the tail lamps
Removing the OE reflectors from the bumper
OE Reflectors
Tail light connector and socket
Wiring out for the connector
New wires to be soldered to the pins for reflectors to work properly
De-pinning was done to solder the new set of wires
Routing the wiring
Reflectors in action - When parking lights are ON
Reflectors in action - When parking + brake lights are ON
Thread Starter #26
Addition of aftermarket TPMS - SensAiry (from TymTix, Bangalore)
  • TPMS was another important addition that was planned since I got the car. I came across this company based in Bangalore and was fully 'Made in India'. Customer support (Mr Ajay) is top-notch and available always.
  • I was particular about the TPMS being an internal type sensor along with a 5 sensors option as the spare wheel is generally neglected. The locally available TPMS are 4 wheel sensors and generic make.
  • The TPMS was installed on my car on the 19th of May 2018.
  • It has been almost 1 lakh km since the installation.
What I paid - Way back in 2018.
The packaging box
The specifications
Sensors and Valve stems
One sensor and valve stem assembled
Sensors paired and labelled accordingly
Temperature and pressure Units settings page
Low or High-pressure alerts on the App
Tyre removed from the alloys for the sensor installation
OE air valve stem cut off
New stem installed
The tool used to pull and fit the stem to the seat correctly
The cloth used over the alloy to protect the surface when using the above tool
Full sensor + valve stem installed
Balancing done after the installation
All sensors post-filling air and driving around for 50 km
SensAiry & Android Auto
The main screen displays pressure and temperature data on the screen
The second screen for the fifth sensor (Spare wheel)
Screen at night
  • The above screenshots that I have uploaded are of the initial stage. Currently, the application has been updated a lot with a lot more finesse.
  • As of now 3 out of 5 sensors have stopped reading out data. After contacting the support team, they told me that the batteries (coin cell) must have died since it has crossed 5 years and the average life of these batteries are 5 years.
  • I have been recommended to replace the sensors on the whole as the batteries can't be swapped out. I'll be making the purchase soon and updating here.
Thread Starter #27
DIY - HID Retrofit in the Headlights
In my earlier car (Maruti Swift ZDi), I had retrofit XP Micro HID projectors in the fog lamps and that made a sea of changes in the lighting output of the car. When it was time to change the car, I decided to perform this modification after 6-7 months of usage.
  • The odometer at the time of installation was ~45,6xx km and was done in November 2018 (1 year after purchase). The current odometer is 1,24,800 km and so far headlight bulb has failed twice. Once it was replaced under warranty and the second time I had to purchase a local brand - Genome D2S bulb.
The bracket set ordered from AliExpress (ready-made for Creta/ix25) for HID retrofit
Red oxide primer for the bracket
Wire brush and paintbrush to coat the bracket
Paint can for painting the bracket in black
Cleaned, sanded and applied red oxide on the bracket (2 coats)
After drying applied paint on the surface (2 coats)
Test fitting the bracket in the headlight enclosure
Test fitting the projector unit in the bracket
Highlighted areas were required to be filed for the projector to be seated correctly. Since we didn't have access to dremel, we had to use the file
  • Morimoto D2S 4.0 Stage III kit
The whole kit
Morimoto Ballast - XB55 (50W)
Morimoto HID bulb - XB35 (35W 5500K)
Morimoto Wiring Harness - HD Relay (9005 type)
Morimoto D2S 4.0 Projector - RHD version
The damaged headlight was procured for all the measurements and test fitting purpose
  • OEM Projector Images
OEM Projector unit
Shield & Motor
Projector casing and lens (fresnel type)
OEM Cut-off shield
  • Installation Images
The bumper was removed for the easy removal of the headlight and routing of the wiring
Headlights removed and taken in for installation
Homemade jugaad to heat treat the headlight for separating the clear lens from the rest of the headlight body
Headlight is placed inside the box for the heating process
The hot air gun is placed on one end of the box to heat the inside (make sure heat is not blowing directly onto the headlight else it would deform)
On the other end of the box, placed the digital thermometer to keep track of the approximate temperatures inside
After sufficient heating inside the box, manual heat was applied at localized areas and prying using the screwdriver to separate the clear lens from the body
Clear lens separated
Retrorubber - sealant added in the channel to re-seal the headlight
  • Fitment images
Test fit to ensure everything works as required
Ballast secured on the frame
HD Relay secured to the radiator frame on the inside
Cut off line without any adjustment
Two screws inside the headlight casing for adjustment (Left and right and/or Up and Down)
  • Lighting output images
Cut-off lines on the OEM halogen projector headlights
Cut-off lines after Morimoto retrofit projector
OEM Halogen projectors - Low beam
OEM Halogen projectors - High beam
After Morimoto retrofit - Low beam
After the Morimoto retrofit - High beam
  • Genome D2S HID Bulb
Purchased these locally from a seller in Hyderabad since one of the Morimoto ones failed.
The packing
D2S Bulb - Pair
Hey Anurag,
Was wondering if you changed the ATF and timing chain? If yes, the associated cost as well as time consumed. Will an FNG do justice or HASS?
PS: Created this ID just to ask you this question :)
