dipesh.vyas said:
hi shrid can you tell me what oil good for my 2.2 ltr vericore pride i suppose to go with mobile super 1000 mineral oil is that ok?
I'm not the expert here, but my usual advice is "as long as you can afford Synthetic oil fill it in. Synthetic oils provide better lubrication, which means your car can run faster" but not in this case. Because usually all cars have a run-in period, which means some wear and tear is pending, after which you can rev her to glory. Because of the lubrication properties of synthetic oil, this process is slowed down. The run-in process lasts around 3000 km. So yeah, 1000 mineral oil is good but just make sure that you fill in the right viscosity and friction rating oil etc., and cross check with the manual for the exact rating. But yet I think you should wait for Viru, mainly because our opinions differ:
[another auto forum] recommends that you change your engine oil after the first 1,000 km. As with all new engines, you will find that some metal slivers have found their way into the oil. From this point onward you can stick to the manufacturer recommended intervals.
If you want the src, PM me.
EDIT: Your car engine oil details:
Car: Tata Aria Pride 4x4
OIL QUANTITY : 7.5 LITERS
OIL GRADE : 15W40
OIL SPECIFICATION : API-CH4+MB228.3
OIL CHANGE INTERVAL : 15,000 kms.
Src:
http://www.cartoq.com/lubematch-app
Formal disclaimer: Again, I am not the expert and this is my personal opinion, nobody should take offence, and blame me in case anything goes wrong...
