Thank you very much Lucas, the 70VLT looks wonderful. i must think seriously about it.
Thank you very much for all the information Shantanu, really you have proved that SMD leds can be made in a such simple yet effective method and low-cost too.
while working with LEDs i have faced some troubles, which i would like to share and have your opinions about that.
when you created the unit have you ever felt LEDs were getting heated up?
i have tried using power LED (3W, 1W 3.6v) to create automotive as well as home lighting.
I used a 3.6 V driver (max 750mA) and a 10w 10Ohm resistor to drive the Units.
i used the resistor to reduce the power as the LEDs were very bright and one got blown because of insufficient heat sink.
is your unit generate much heat?
i then used an old CPU heatsink to test another 3w LED, after 7 hours, the heat sink lost its coldness. But when used with the resistor the light was not good. but the LED did not heat up.
Then tried a different one i connected 8 leds
5mm.
in a ring like fashion
then tried various methods (series, parallel, series parallel mix) it gave ample light on 12V driver.
also just showing the power of a 3w led downlight
a complete dark room. runs on 12v but even with the heatsink after 4-5 hrs some heat is shown on the surface but no problem.
i have tried to make LED lights many time, but this heatsink issue has always troubled me. i am moving towards createing 12v devices so that i can use them in car as well as home too.
but with SMD leds bought from ebay i never faced the heat problem.
@Shantanu.lko have you used resistor in your LED DIYs?
If we are able to drive the power LEDs successfully then we can bring a revolution in low-cost, energy efficient automotive lighting. please share your experiments too.
@dhruvpandit thank you very much.
