Sethu,
I like your enthusiasm in doing DIY on your car, but remember to be careful doing these things and do not become an "Abhimanyu" in "Mahabharatha"[;)][:)] after opening everything.
Thread Starter #182
Sethu,
Yes Mr. Gurrala. I never become victim. Pls go thru my post that I wanted to do it either by a work shop or electrician or service center. As I had told in in person as well as in the threads, if I am not sure of thing I will touch it. Even at home I do [electrical/mechanical/plumbering] work I follow the same. For example, I can separate parts of a table fan or Ceiling fan, clean it and re-assemble it.
But I never venture into motor parts of the fan because I do not know much about it.
Hope I will try to follow the same for my car also.
ghy
Sethu can you please specify the dimension of the lights? Please upload some snaps placing a scale beside the lights.
Thread Starter #184
Lucas, i do not know exactly, just without seeing the light currently am saying this. Light is at home.
Length = 2 - 2 1/2 inches
Width = 1 - 1 1/2 inches
Height = 3/4 - 1 inches
i can give you exact measurements after reaching home.
Anyone using steering mounted blue tooth kit for both controlling their audio system and also for taking the calls???
I have SPARK LPG LT and i am looking for the above accessory in bangalore.If anyone has any information on this please do letme know.
Thanks.
Chevrolet Spark LT modifications
Dear All,
I am using SPARK LT and i am looking for below listed accessories in bangalore.
1. Head rest modification for back seat(at present there is not head rest available)
2. steering mounted blue tooth kit for controlling audio or taking calls.
3. alloy wheels.
please let me know if anyone has idea on these.
Thanks
Thread Starter #187
@Chandra,
I do not remember seeing any sparky owner in Blr. But we have our guru Mr.Varun who can help in any car. Hope he would reply to your post soon.
Even though I have spark that too in chennai, I have not thought about all these modification as of now. So did n't even put thought process on it. Sorry.
Dear All,
3. alloy wheels.
Thanks
You can get head rests from any model (maruti), fit it as I have done it in my car. Any upholstery professional can do this, cost will come upto 1.5k.
Here is my thread please refer.
http://www.theautomotiveindia.com/forums/ownership-reviews/5044-my-modified-maruti-800-a-40.html
I have no idea about bluetooth kit.
@Chandra,
Thanks. BT kit may be available in JC road, I will try to get some info about that.
Varun, Thanks for the reply.. any pointers for upholstery professional in bangalore who can do this modifications??
and will be waiting for your reply/information on BT kit..
Once again thanks for your response.
Re: Chevrolet Spark LT modifications
Dear All,
3. alloy wheels.
Thanks
@chandra: my inputs to the points you mentioned, might be of help.
1) 2008 Spark LT came with rear seat headrest. See if you can use this information and get those fittings from CASS. I am attaching the picture of my Spark with the headrests.
2) Steering mounted controls > you will get the IR ones which control your head unit as a IR remote. I have used them and works quite well, but not when the steering is rotated by 180 degress. But to a good extent it works. You will get BT enabled ones too (just search on ebay), but mine works only as IR remote.
3) Alloys: Get them for the proper tyre size; should cost you from Rs.12K to 14K depending upon brand.
Thread Starter #191
That was a really nice idea. Thanks for that. In this case, headrest could be from chevy itself. may be the fittings for headrest need to fabricated separately as Mr. Varun has did.
@Chayan.. Thanks for your reply.. and regarding that BT kit i don't want to try in online becuase mine is 2011 sprak LT LPG which has company fitted music system,suppose if the BT kit is not compatable with my spark head unit then i can't do anything with that BT kit and i don't want to take the risk.if there are any showrooms which can do this in bangalore i will directly go and check there.
Thread Starter #193
@chandra, pls let me know the FE you are getting in both LPG and Petrol. Mine is 2010 model which I took in 2011 Oct.
This is my FE
In LPG mode
City - 9-11
HW - 12-13
In petrol Mode
City - Not yet checked since most of the time I try to use LPG
HW - 13-15
@sethumurugan.. FYI..
In LPG mode
City - 9-11 with AC and without AC i never checked
HW - 13-15 with AC if i go in 100/120 KMPH and when i checked without AC recently it was close to 16
In petrol Mode
HW - 13-15
Hi Chandra, did your music system come with IR remote? If not these would not work.
There are other BT modules that connect to the music system via FM radio, but not that well integrated overall.
