Brakes Booster & Brand New Clutch on Maruti 800
Re: Booster Brakes & Brand New Clutch on Maruti 800
Hi Guys, here we go.
Original single outlet connected for AC:
The booster kit goes in:
Booster kit with air filter:
T-Joint Zoom for Brake booster and AC:
Full assembly:
In my case too, did not bend the air filter. It just fit in the space and I tested starting the engine and turning it off multiple times. It did not touch. The brakes are really good and I feel like driving any other power brake cars. I now dint have to worry if the car would stop or not [:D] Peace!
I ll post more information on my experience and suggestions in sometime.
Thread Starter #77
Welcome to TAI & Excellent update Sathish. Did I miss your ownership thread? If no, then please start your ownership thread soon.
Hi, Thanks to ss80 and Varun for this informative thread which helped me know about this stuff for Maruti 800. Though there were pics and information scattered in this thread, I was little not clear on what was exactly needed and how it needs to be done (eg. did not understand why an extra hydraulic brake line in ss80's pic was required and where it fits etc). Hence here is a short write up on the procedure for "M800 carb cars with AC only". Note below for M800 non AC carb cars.
Parts purchased:
1. KBX brake booster for M800 from Maruti Genuine Accessories shop (MRP Rs. 3750). This did not have any other accessories other than the master cylinder attached to the valve. (Might be cheaper in other stores). If you get all other spares along with the kit, then you are ready to go to the garage, skip all below.
2. Extra brake hydraulic line as the existing one will be shorter in length to fit the new booster kit (Rs.30 - from local accessories store)
3. A rubber hose for vacuum to be passed to the booster kit (Rs.30 - from local accessories store)
4. 2 clamps to hold the rubber hose tightly at both ends (Rs.20 - from local accessories store)
5. T joint which can be purchased readily from a lathe shop (Rs.100 - from lathe shop)
6. 500ml DOT 3 or DOT 4 (castrol or TVS) brake oil (Rs.130 - from local accessories store)
At the garage:
MASS did not agree to install this and advised to contact a local garage. Hence if you do not know the garage person well, then do not allow him to remove anything other than the air filter for this job unless removing any parts demand. Next:
1. Remove the connecter in the manifold (air outlet point) which might have a rubber hose for AC connected to it.
2. Remove the air filter (just 2 nuts and 2 tubes needs to be removed to lift up the unit)
3. Remove the hydraulic brake lines (4 pipes) connected to the current brake cylinder valve.
4. Remove the master cylinder cover and disconnect the cable that connects to a power/signal source.
5. Remove the brake master cylinder. There is 1 cotter pin and 4 nuts that needs to be remove from inside the car (above the brake pedal)
We are done with uninstallation. Now at the lathe shop:
1. Take the connector (which we removed in point 1) to the lathe shop and get a T joint. The T-joint must have thread of similar diameter to the one removed so that it can fit into the manifold.
Back at the garage:
1. Place the new brake cylinder with the valve. It will directly fit the 4 holes. Tighten the nuts from inside the car (above the brake pedal) and put back the same cotter pin or new one
2. Connect all 4 hydraulic brake lines. One brake line will be shorter in length and this is where we will have to remove the pipe and replace the new one that we have bought.
3. Put back the new/old brake oil cylinder cap and connect the wires back.
4. Connect the T-joint to the manifold. It will have 2 open joints, connect 1 to AC (using the small tube). Connect the rubber hose that we bought to the second open end of the T joint and the other end of the hose to the booster kit. This acts as a vacuum source for the brake booster.
5. Connect the clamps to both ends to ensure that the vacuum tube for brake booster is intact.
6. Fill the brake oil and bleed several times to remove the air from all 4 wheels
7. Connect back the air filter cover and the 2 tubes that comes above it.
Note for non-AC carb cars: T - joint might not be required. Just 1 open end and it can be connected to the brake booster directly as seen in ss80's pics. Rest of the procedure remains same.
Start the engine and check if the booster kit gets in contact with the air filter. We are done! Test ride and feel the effect of the new brakes. You are now ready to drive on safe speeds without worries whether the car will stop as required or not!
This is definitely a DIY as Charithao said provided we have the right tools for the job. The above information can also help explain the garage person if he insists on add, drilling or removing any other parts. This is a must mod for all Maruti 800 owners and you will feel the difference and peace of mind at any speeds. Thanks Charithao for your last minute pics. I can update this post with step by step pics if anyone is interested.
Experts, please update if I had missed anything.
Disclaimer: As brakes play one of the most critical role in our cars, please perform the task at your own risk. Owner/Author accepts no responsibility or liability whatsoever :biggrin:
Happy driving [drive]
The T Joint comes in the kit.You don't need to get one if you buy the KBX kit.
Unfortunately if you buy the parts from MGP you get them all separate and the T joint need to be made at a lathe or a specialist engineering shop.
If you have an A/C you need two open ends on the T-joint,one for the booster and one for the A/C.
You just need to remove the old master cylinder and fit the booster cum master cylinder in its place.
MASS does make a fuss about it, but many are willing to do the job.Its not rocket science so a local garage can do it as well.
Just be sure to check the brake pedal feel before and after.Also the booster needs the engine to be running else its just like the old mechanical brake.
If you want to be sure, just pop the hood and look in the engine bay.If you see a Vacuum tank behind your brake master cylinder, it means you have a brake booster.If not, you need to fix one.
Yes, it is very easily available in the market.If you have a brake booster kit installed you can go for DOT4 brake oil.
