Brakes Booster & Brand New Clutch on Maruti 800
Thread Starter #46
Re: Booster Brakes & Brand New Clutch on Maruti 800
Okay, now thats something I never knew all these days, Are you currently using tyre milk in your 800?
Ran out money after getting 4 tubless bridgestones [cheers]So just tyres and nitrogen[:D]
delhi
Re: Booster Brakes & Brand New Clutch on Maruti 800 contd...
Dear ss80 ,
I have enquired my mechanic for installing booster brake in my 1997 maruti 800. He say yes it is possible but a plate is needed for installing master cylinder. Is it true.
Thanks
What plate ? It is a direct fit no need of any modifications..
In carb 800, even there is no need to drill a hole for tapping the vacuum for the brake booster..
@aloktyagi3547:Just get the kit that you see on page 1.
Mechanics are really lazy and they make excuses and tell stories either to delay the work or extort more money from you.
No plate is needed.
I have the same kit installed on my '97 800.
Thread Starter #51
It is a direct fit, no drilling holes etc. I suggest try with a different mechanic :)
Colombo
Guys,
I am from Sri Lanka. Is it possible to get a KBX brake booster shipped to Sri Lanka? Is there a place that I could check this out online?
Thanks.
I guess this is not available online, why not check with your local dealer if he could get one for you. You can ask for 5 speed mpfi 800's booster.
Colombo
Thanks for the quick reply. I'll check with local dealer. Thanks again.
You're welcome @Charithao.
If you purchase the kit make sure it has all the components that are shown at the start of this discussion on Page 1.
Colombo
Thanks for the reminder. I am planning to buy one tomorrow. Will let you know when I get it. Thank you all for the directions & for the info.
Colombo
I managed to find the booster but it's the MGP one so only the booster is there. [frustration] I guess I have get the brass joints and stuff made in a lathe shop. [:D] I'll let you guys know when the things are done. Thanks for the support.
That T joint Is hard to find.Did you atleast get a proper vacuum pipe with the booster?
If you have not purchased the booster it would be good to ask car part dealers for a KBX kit.That would be the better option.
