Re: Booster Brakes & Brand New Clutch on Maruti 800
I had this small issue after I upgraded the brakes. Simple problem, simpler solution
The air filter box was touching & passing the vibrations to the booster unit! As the new booster is slightly more in length than the old (non booster)one.
Spoke to Varun (actually he had predicted this on that day itself & also the solution was ready) & did a small change to the air filter box.
Using hammer made a dent on the air filter box (picture below)
Accidentally I broke the holder thing that the nose of the air filter had
so cut that entire section ![Cheers [cheers] [cheers]](https://www.theautomotiveindia.com/forums/images/smilies/Cheers.gif)
Now the sound has changed (intake sound) and engine breathes easily than before.
Please Note: This does not do any harm to your engine/ any parts. Air is still sucked through the air filter only. Instead of that long L shape suction, now its shorter. To create a dent, remove the air filter box & then hammer, do not hammer it when it is in the engine bay!
M800 guys, plz do post your pictures on booster upgrades etc here.
