Re: Booster Brakes & Brand New Clutch on Maruti 800
Hi guys ,
Thanks a million , for your replies/ inputs . Sorry couldn't reply earlier as I was busy as hell .
Engine performance reduces only when the tube ruptures, it isnt a thin tube its a proper vacuum tube.You can cover it with a corrugated plastic cover.If it still ruptures the brakes return to their mechanical self(how they were before booster was added).The booster only works when the engine is running else its just like your factory mechanical brake.
This is what I wanted to hear
Varun560061 said:
Fitting an booster won't effect the performance,mileage just need to increase the rpm/idling a bit after this upgrade as the booster needs to be filled up..
If I am not wrong , the idling rpm of a carb M800 is 800 . So should we go for a 1000 rpm idling rpm with brake booster ? Please suggest .
ss80 said:
I do not want to debate on the stock brakes, however the booster does make a lot of difference. Stock brakes in my car needed more muscle power & reaction time, the booster makes the braking job easier & the ride safer.
There is no debate on the stock brakes offered by MUL on the M800 . I mean , I did say that I have no complains from the stock brakes , but if the brakes get better with a booster kit like yours , I will be pleased , very pleased .
And as far as better braking is concerned , I might even think of getting the Bridgestone 165/60R12 71H Potenza GIII tyres . Swap the stock disc and capiler for a bigger one and even get alloys for better cooling of the brakes . But I wish I would get the time for these mods .
ss80 said:
Drive some M800 with Booster fitted & I am sure you will love it. The pipe you are referring to pretty tough and can hold on to its place for years!
I have an idea of booster assisted brakes . I also own a 2004 Honda City and have driven Civics , Corollas and Accords
So with a booster kit and Bridgestone 165/60 R2 71H Potenza GIII Tyres on a light car as the M800 , I would imagine the braking be as good as the Honda City or even better .
ss80 said:
In carb cars (mine is carb too) the idling will slightly reduce after the booster is fitted, so in traffic conditions till your engine is slightly wamred up. You need to press the throttle gently (to increase idling).
I am sure this is the reason why Varun suggested to increase the idling rmp .
ss80 said:
IT IS SAFE & WORTH THE MONEY SPENT, GO FOR IT. Accessories like ICE etc alone eat up 5K (min) to 50K (or even more), better brakes always keeps you safe.
I can't agree with you more . You cannot put a price on priceless things like the safety of your life and the lives of family members and anyone who rides in your car .
Spinner-Wheelz
