Dilli
it's not famous like Venom nor very professional.
they supply subbox to this car ICE dealers. ICE dealers wont make fully custom made and will charge more. so i find this guy and went to his factory.
inside cabin , it will become too bright and looks cheap if it's white in color. it will look like those indica taxi and maruti Van , disco dancers , who modifies such things.
Will try to find Venom.. I need only professional sub-box now...
Ahh its that bright for the cabin.. will get it done in the boot soon and will post the pic...
trunk flexing.
got some modification in my subbox today.
it's better seen in HD.
@kunaL
do you hear some vibration(squeaking) noises coming from under the boot , near rear tyres when heard from outside , while playing subs.?
i dont know what is loose there and vibrating so much? cudnt find out. same noises comes in my friend's i10 too.
is it coming in yours?
Trunk flexing in my sedan - infinity 1260w w/ JBL GTO1004e - YouTube
Dilli
trunk flexing.
@kunaL
yup i do get vibration noise, in medium level sound, it annoys me a lot, it comes inside the car and outside as well... will get it checked tomorrow as wkend is here... will upload new video, pics tomo...
outside vibration sound is not heard in the car for me.
inside sound comes from 2 main things.
1. sunglass holder
2. rear plastic plank..
both are so much annoying. i tried to fix them both but sound has not gone 100%. I will try to stuff some more sponge below the rear plank through the hole in the boot (that is used to change the rear brake light bulb)
Sunglass holder , no idea. as i have spects , never going to use it , i am thinkin to stuff it with sponge too.
Dilli
1. sunglass holder .
below is the latest video.. hear it in your home theater.. in the video u'll notice my new sub enclosure.. gotta remove the old wooden box.. vibration has reduced a lot because of this new sub enclosure and punching bass has enhanced a lot, but sub effects outside the car has reduced.. i thot outside sound will increase.. dont know what's the reason..
Vibration noise is still coming inside n outside the car, check it out n advise some solution.. [confused][frustration]
gonna get my 150 rms foacls today.. [cheers]
Sub Enclosure test P.1 - YouTube
Dilli
@ Neil: Also advise which is the best amp for my 400RMS sub and 150RMS ovals. And having a mono is a good idea or apm is more then enough? I have'nt used mono till date for sub, have always used amps. lemme know what you think. n also tell me what all you are using in your sedan with model numbers.
i was thinking about JBL GT5-S644, 800W 5-Channel amp.
[cheers]
@ Neil... also advise which is the best amp for my 400RMS sub and 150RMS ovals... n having a mono is a good idea or apm is more then enough? I hvnt used mono till date for sub, have always used amps... lemme knw wat u think... n also tell me what all u r using in ur sedan with model numbers..
i was thinkin abt JBL GT5-S644, 800W 5-Channel amp..
[cheers]
Is your sub dual voice coil or single?
don't have access to wifi currently can't suggest amp or see the vid
if sub is 400 rms thn give it at least 400.
Mono would be best for high rms sub.
I have jbl gto 1004. Gives 150 X 4. Bridged two at 300 that supplies sub. And sub is 300 rms too. Other two ch rear helix speakers. Front are stock. Planning to add focal comp in jan.
If your sub is dvc 4 ohm then you must buy monoblock.
If you want outside car sound then those punching vibration will be less inside or vice versa. I like punch then outside sound. So tuned my box according to it
Dilli
My sub is 400RMS, dual 4ohm voice coils (2/8ohm Impedance, made in Mexico).. even am thinking about mono.. any idea which is the best mono for this powerful sub? dont wana go for expensive stuff, so lemme knw cheap n best..
wats the cost of ur amp? have u done anything with ur trunk to reduce vibration noise?
Dilli
@ Neil..
Shopkeepers here are suggesting me to go for Sony Mono XM-GTR3301D which is 1100W & 330 RMS for the sub @ 6k, and also suggesting Sony 4 channel amp which is for 5k..
What do you think about the Sony mono? Could u recommend me any good cheap 4 channel amp for the FOCAL's and Comps..?? Need to know asap dude.. Is there any other way to contact you??
