thanks neil bhai.but where to place hi-low converter? like the amplifier is place under front passanger seat? r u sure this is a easy installation and any mechanic can do it?which other car has stock HU without pre-out so hi-low has to be fix?i will give example to mechanic.maybe he would have done work before.
and by chance wrong installation any chance of car catch fire/any other serious? any other advise please neil bhai ?
hi-low converter is small thing. it will be hanging behind the HU.
no idea about the cars without preout and any serious damage it can cause. but i think it wont cause any damage yet i'm not sure.
just show the above photo of hi-low converter. if he knows , he will definitely recognize it.
good luck.
Thread Starter #182
verna
All around India :)
This is written on Hertz 4.1 amplifier :
HE 4.1 The HE 4 Is A Four-Channel, 800W (Max) Amplifier That Can Be Bridged In Dual Mono As Well For Utmost Flexibility; It Is The Ideal Choice To Upgrade Your Factory System: Pre-Amplified Inputs As Well As Hi-Level Inputs Offer The Possibility For The HE 4 To Be Interfaced With Any Head Units, Including Factory OEM Systems. Real 12dB/Oct. Continuously Adjustable (40 To 400Hz) Active Crossover With Lo-Pass/Hi-Pass Or Full Range Settings On Each Pair Of Channels Ensures The Best Acoustic Performance Of Your Car Audio System Especially In Front Plus Subwoofer Application. The Advanced Electronics And The Optimized Cooling System Ensure The HE 4 To Provide High Power, Even Under Difficult Conditions.
I think hi&low converter not required neil bhai? nick bhai ? i am confuse again
To use Pre-amplified inputs - you will need hi-low converter and scosche wiring kit
To use hi-level inputs - you will need hi-level output in your HU and hi-level wiring kit(i have never seen it how it is)
Thanks niel for sharing pictures. Now i am coming to conclusion about ice upgrade. With this handful important information i can approach the dealer so that i can opt for safe and correct installation.
I am going to install hi low convertor. But which brand should i choose?
Hertz HE4 or Kicker or JBL as per availability i am going to choose. All these are good brands. I will go for Blaupunkt Bass tube 1250 Watts which sound really good.
3 way component speakers of infinity kappa brand.
I think above combination will work fine without trouble? What you say guys?
i have no idea about brand of hi-low converter. didnt notice.
good choice
Thread Starter #186
verna
All around India :)
which give better sound?3-way speaker 65 watt rms JBL or 2-way speaker 75 rms (hertz 165) ?
Focal solid is good amplifier? i hope there is no problem in there... fitting of "hi-level" wiring require in focal solid like as hertz HE4.
i will then go for a focal solid and 3-way from JBL/2-way from hertz. which is best sound and more surround affect?
Mumbai MH01/MH46
dnt take jbl hertz is anyday better.
please understand for surround sound and better production of hi and mids go in for a component speaker you wont regret it. 3way speakers can give louder sound and sound quality is best of components since tweeter is separate it will produce better surround effects
if you go in for hertz you will save money on the converter. i havent heard much of focal solid.
regarding sound between3way and 2 way a 3 way will give better sound but hertz may give better performance
there are reviews you can google up very helpful and will make your description more concrete
Thread Starter #188
verna
All around India :)
In component system,i am confuse nick bhai where to place tweeter and other external part.we will have to paste/stick it to car/screw it there.i dont like.
"if you go in for hertz you will save money on the converter." -i did not understand, if HE4 amplifier is used,then hi/low converter is not required?
but neil bhai said is required and some else cable also reuire.
please confirm if u can , nick bhai.
neil bhai say "To use Pre-amplified inputs - you will need hi-low converter and scosche wiring kit
neil.vernafluidic is now online Add to neil.vernafluidic's Reputation Report Post Reply With Quote"
Thread Starter #189
verna
All around India :)
I was thinking that hertz ECX 165 great, but only 2-way , so woofer and tweeter no mid. but 75 watt rms
JBL JBL GT6-S366 65 watt rms ,3-way,so woofer,tweeter and mid.so i think more complete sound we could achieve, what u think ?
MUMBAI
hey verna both the speakers sets that you are looking at are coaxil speakers and not components
check this link this is a 2way component Amazon.com: Focal 165 VB: Car Electronics
MUMBAI
yes,i know. my problem with components is where to fix tweeter/etc. other external devices they provide with main speaker ? i dont have idea.
hey verna the front doors come with a speaker and tweeter seprately in the door so in a 2way component setup they both go in original places
on the door and the crossover that is present is placed inside the door itself unless u want it visible u can mount it outside on the door but the wires will be visible
Thread Starter #193
verna
All around India :)
That is what.i do not want visibal wire. which will be better speaker ? JBL GT6-S366 65 watt rms 3-way or Hertz ECX 165 75 watt rms 2-way ? all 4 speaker i will change and amplify with 4 channel amplifier 4x75 watt rms (hertz H 4.1 or focal solid, which ever does not need hi-low converter is better) .
please help
MUMBAI
i will post pics of my setup today evening after i open the door panels for damping
will give u an idea of how to place the crossover without the wires being visible
and not sure about the hertz amp but the focal solid 4 will not need hi low converter
Mumbai MH01/MH46
are you familiar with your home music system? the way you connect your speakers using a red and black plug +- thats the same way the head unit connects the speakers. and then how do you connect your dvd player to tv. ? there will be plugs yellow red white. this is the way to connect to the amplifier. in the car some head units donot have these pugs hence we have to use a converter to change the speaker wire and make it amplifier connection.
the hertz amplifier will readily take in the speaker wires with out any converter as it is in built. other amplifier does not. same like for your internet if your laptop has no lan port you a lan router and connect it from usb .
tweeter will go in your front door just behind the mirrors those crossovers go in the door panel or near your amplifier
