Aftermarket Tacho Meter / RPM Meter
Port Blair
Hi Folks! i wanted to install aftermarket tacho meter in my maruti omni MPFI 2001 model. i have certain doubt if you can clarify.
Whether for MPFI model there is dfferent proceedure for installatio.
Where is will get a 3 cylinder tacho model for omni. will A star tacho will do?
Thread Starter #92
Yes A-star tacho will work, I guess omni shares the same ecu of 800, so there is no separate wiring from ecu for tacho.
Port Blair
Thanks varun for the clarification!
Do you have any idea about where the ignition coil is located in maruti omni. i have certain confusion in regard to that.
Oops reading the thread made me realise i too can blow up the ritz tacho in the esteem ! Is there any way i can avoid this guys :help:Varun is your tacho working
Thread Starter #96
No my tacho is not working, I blew up totally 2 tacho's..
Dont worry, just try it in your car, may be it will work fine with carb models.
Kochi
Dont try ritz tacho on esteem it will not work I tried in a carb esteem its not perfect and showing morethan 4k on idling. better to buy an aftermarket universal one IMO
Hmmm ive already bought it ..... spent some vitamin M, no looking back now will install it.... of course if some one wants to buy you are free to do :stupid:pls Pm me in case anyone wants to buy
Nagercoil/Kollam
You will get a universal tacho, which will have options to change to 2,3 or 4 cylinders. Costs around 4k.
Before that check if you have connectivity for RPM, as we don't have in ours. [frustration]
then how your is working? BTW the connectivity can be checked with a engine mechanic or an electrician ? or if i get different snaps you will tell me ?[:)]
