Re: Why Aria Failed to Take-off But XUV Did??
Many of the issues have been sorted out by M&M -
Vehicles were recalled and brake discs were changed.
This is not M&M's fault, still the owner was given a new tyre, isnt it?
Cruise control never had any problems. One thing I observed is that those complaining about issues with CC have not read the manual.
The manual clearly states at what speeds and what gear the CC will activate.
For example, one guy was cribbing that CC does not activate at low speeds in higher gear. Then what? He wants his car to stall after engaging CC?
Another guy pressed the RES button instead of SET+ and was then complaining that his car picked up speed in traffic. The manual clearly mentioned what these buttons do. It also states not to use CC in traffic.
This was the same when CC in Scorpio was lanuched. Many people dont know how to use CC in manual transmission cars as they dont bother to read the manual.
Many cars with Projector setup have a blind spot on the RHS. this is to avoid glare to oncoming motorists. This is not a defect, its designed like that.
Solved.
Impact sensors need to be deactivated. Solved.
There was no failure, it used to hang. Software upgrades have solved it.
True. Mahindra never makes fuel efficient cars when compared to competitors.
Again, these people did not know how to use the ACC. I can give you an example of a guy, who instead of pressing 'Auto' button, pressed the 'AC' button, thereby switching off the AC compressor. And then he complained that the AC cooling is not good !!!
I guess the only issue still pending in the XUV is the TPMS behaving weirdly in some cars. That is yet to be solved.
Hi All,
I was going thru a thread (on another forum) dedicated to Niggles so far found in XUV500 and the list seems to be ENDLESS.
Brake pad and disc related
Tyres giving away with cuts and bubbles
Cruise COntrol Problems
Headlight issues
The Famous Door not closing issue
Sensors going kaput or activated unnecceasrily
Infotainment failure and problems
Low milage problem (9 in city and 11 on highway)
AC not effective or inconsistent
