If you are having loss of pressure, you have a slow leak. Get a puncture patch. If tyre is out of warranty, get a tube for it. Tgis doesn't convert it to a tube type tyre, just guves it the additional protection so that it doesnt blow out at speed. Only remember to put the tube in both side tyres. If you still have concern, use these tyres as rear tyres or keep the punctured obe as spare
Ameyam
Thanks Ameyam for your suggestion - Just to be clear -> Here 'Puncture Patch' mean the put patch from inside of the Tyre by removing the tyre from the Rim ? Right ?
Please let me know (noob question) -
1. As suggested about installing Tube - Say if another new nail or something go through the Tyre and penetrate Tube Wall the Tyre will be flat and out of Air the minute it hit the Tube Wall Right ? Please confirm this...
2. So both Tyre in the same Axle need to be Tubed - I understand this part - But if I do that - I need to Shift those Tyre (Tube Installed) at the back because there is Less Load ? Right ?
Please let me know....
So you had a long drive I presume
. How was the performance of your Ritz except decline in tyre pressure level?
NO - This is my normal usage - When ever I'm able take out her from my congested place (as you know) she usually clocked 110 - 137 km in a Day. Speaking of decline of Tyre pressure - Feeling None - Only after 24 / 36 hours affected Tyre got Bulge at the bottom other three tight and straight.
Wish I can take her out to a Long Drive - such as PURI.
