Ever Wondered What Do Those Numbers On Side Of Tires Mean? Mystery Solved
Ever looked at your car’s tyre and wondered what those alphanumeric codes mean? They are not just for the US Department of Transportation or the manufacturer to understand, you too can extract valuable information from them. Apart from brand, model and size there is more information than you think.
Type
First letter usually indicates the tire class. As LT means Light Truck and designates that the tyre is suitable for small payload trucks. Same way tyres for passenger cars are allotted the letter “P”
Section Width Tread(mm)
Next three digits account for the section width of the tyre. Section width is basically the width of the tyre from one side wall to the other.
Aspect Ratio
This actually tells you about the height of the side wall. An aspect ratio for example of 45 means that the side wall height is 45% of the section width.
Construction
This letter donates the construction. If it is R it means radian which means layers of fabric run radially across the tyre.
Wheel Diameter
This number is designated for the wheel diameter, which is usually given in inches.
SOURCE => Ever Wondered What Do Those Numbers On Side Of Tires Mean? Mystery Solved
Cheers,
Atul
Type
Aspect Ratio
Construction
Wheel Diameter
Cheers,
Atul
