To add from my experience:-
Set the Wheel Alignment: Wheels are aligned when all of them face an exact same direction. Well-aligned wheels ensure a smooth ride with less wear impact on the tyres. On the other hand, wheels that are not aligned bear more friction causing a rapid wear. Not only this, but unaligned wheels can also compromise the safety of passengers and increase the fuel consumption to a significant level.
Replace the valves each time you fit the wheel Valves and valve caps are very small in size but very high in utility, as they can hold the pressure inside the tyre. They can also be used to extract out some air if the tyre is over-inflated. As valves are made of rubber, they deteriorate very quickly. So each time you fit the wheel, try to replace old valves with the new ones. This is certainly an inexpensive maintenance tip, but can increase the life of your tyres to a great extent.
Replace the tyre rather than repairing it: It is often asked that after how many repairs a tyre should be replaced. Well, this can only be answered by an expert after analyzing the condition of your tyre. It also depends on whether the tyre has undergone major-repairs or minor-repairs. We suggest replacing the tyre after a couple of major-repairs.
Improve your driving skills: The lifespan of your tyres is also majorly dependent on the way you drive. Applying forceful brakes frequently and pushing the accelerating pedal suddenly lead to rapid wearing of your tyres. Drive calmly and take time to accelerate and decelerate the car to put less pressure on the wheels.
