Before a month i heard some sort of sound from the steering column and i take the vehicle to the service centre they says that the the intermediate shaft to be replaced and i said that replace after the replacing of the shaft there is no sound at all . But after some days i found that some sort of vibration and some sort of uneasy while handling the car .There is no problem in handling the car . What i have to check to solve this problem .
My car is Toyota Qualis Diesel model 2002 odo 138 K . Please help me regarding this matter
Hi Duttan,
Before taking the qualis to workshop you check Steering Column Rod and Steering box Bed. Manually you can check the shake easily.
First you check inside the cabin. Shake the Rod and check the feel of it.
Secondly open the bonnet or Turn the right wheel leftmost and check the rod which is the join of the interior rod whether there is any shake while touching to the steering box.
Note : Try it in both mode, starting the engine and check the sound. Next switch it off and check for the sound by shaking it.
Surely you can identify the reason.
Ambylovers,awesome work going on the Qualis,The final outcome-A brand new type 2 Qualis.Sorry for posting late.
Thanks Shrijit303,
In my Car only the grill and lights are of type 2 and everything remains with Type 1 model itself. Original Toyota Spares cost you more, So only the front view i am trying to change.
