The Grey Skid – Chevy Beat TCDi LS (December 2012)
Thread Starter #378
deville_56
January 2022 - Misc Updates
With RH caliper worked multiple times and LH untouched, thought of having a look at it.
Grease was all dried up.
Decent thickness left with pads and rotor.
Piston pushed back with C-clamp.
Had copper shims on. Removed them. Would add new if there is any rattle.
Boot that was swollen on the RH, looking okay on LH.
Added some Nutella [lol]
and installed back.
Gave a quick wash, not a thorough one.
KBX pads.
One side had lines from the rotor.
Installed pads.
Pad with branding was installed inside, swapped it. OCD issues.
Installed caliper. Wanted to paint them, but couldn't.
Water in fog lamp due to dislodged rubber seal. Fog lamp bezel painting also long pending.
Cleaned up and installed bulb properly,
Replaced missing fender liner clips.
Tested for any issues.
Aftermaths of swapping the pads. Decreased and disappeared over time.
Checking turbo spindle for any play.
Perfectly fine. Cleaned before putting back. OE turbo is TEL.
Windscreen shopping for Harish.
Delivered safe [cheers]
Thread Starter #379
deville_56
February 2022 - Updates
Hits 75k mark.
Bought Areon, Bubblegum flavour. ₹ 360.00
Service light was popping up intermittently. Scanned by @vishnu vichu and showed ECU internal malfunction, glow plug controller error and two remaining plugs dead.
Grabbed my multimeter and checked the resistance to find the dead ones.
Last replaced one had proper resistance, should be between 1 and 6 ohms.
Other two were having higher values.
Checked controller voltages too, 7.5 V at initiation and 2 V after a second.
I've got to order two more plugs.
Thread Starter #380
deville_56
March 2022 - Air Filter
Got Purolator this time. Last time, it was Sofima.
Purolator PI-2924 - ₹ 368.00. Got for ₹ 331.00 from Capital Automobiles in Aksharaveethi. Seems many shops offering 10% flat mechanic margin for certain brands like Purolator, Wurth, etc.
Customary new vs old photos. Replaced at 9000 km/2-1/2 years.
Installed.
Bought new O-ring for MAF sensor. Measured dimensions and went to Sara Agencies, where there is assorted collection of O-rings. He was adamant about bringing old ring or the part to choose the right one. Scrolled through his box and got the best match.
Removing MAF sensor.
And he turned out right. Won't fit. Slightly bigger. Seems Chevy stopped the part and the specific part missing in Boodmo page. OE was silicon ring and new one was nitrile rubber.
Installed back and prepped the engine bay.
Thread Starter #381
deville_56
March 2022 - Fuel Filter Replacement
Got Purolator again,
Purolator PI-3881₹ - 488.00. Got for ₹ 440.00 from Capital Automobiles. Bought along with the air filter.
Location. Brake hose hinders access, but managed last time without removing it.
Drained the fuel in the filter housing through the drain plug.
The plug.
36-mm socket, the biggest one I have.
Open the cartridge bottom and remove the filter.
This is where the drain goes.
Screw it back.
Replace the O-ring. OE ring was bright red.
Old vs new. Ran just under 8k km in 2 years.
All set to install.
Filter housing.
Hose was blocking my way this time. Last time too, but made it through. Decided to take it off and make some way.
Clamp out.
Filter in.
Clamp in. Laziness makes life hard.
Removed fuel hose from the high pressure pump and primed a couple of times to remove any air as recommended by @Auto_Psycho in his ultimate Beat maintenance thread.
Plugged back and started and everything was fine.
Ending my car life. With my son graduating from an infant to a toddler, there was great peer pressure on stopping running behind cars, allocating more fund for diapers, redirecting if any left to saving for the future and spending weekends with him. Made (pinky) promise that I would do only absolute necessary maintenances and stop entertaining others' DIYs and bothering about anything other than mine (My Google Calendar always pops up with service/ insurance/PUC reminders and purchase anniversaries [lol]). Made my mind to treat them as just A to B appliances and my car and their cars (*bike, scooter, cycle as applies). Happy ending.
And then I was scrolling through Boodmo and came a package [gun]
Thread Starter #382
deville_56
March 2022 - The Mysterious Boodmo Package
It turned out to be the rear wiper motor. Rear wiper had been in my bucket list ever since we had our Estilo, but never materialized. Whenever I see a Beat LT at a breaker yard, I would inquire about the rear wiper motor, which would be gone by then. Recently, almost got hold of them, not one, but two. Price quoted was insane. I was thinking of sending someone good with negotiation, but draw a conclusion that it's an unnecessary expenditure. Then, the Boodmo search mentioned in last post and original price was way less than the scrapyard price, and couldn't abstain from ordering it.
Rear Window Wiper Motor - J95152637 - ₹ 2,456.00 + ₹140.00
The motor. Couldn't find an image anywhere on the web.
Made in Korea.
KAMCO make, Bosch brand.
Three pin connector. Positive, negative, and park.
Disassembled the same day, couldn't resist. Linkage said M200, aka our Chevy Spark, but not sure about the fit, maybe a different clamp (and part number).
All holes in place and the clamp holes aligned perfectly.
Thread Starter #383
deville_56
March 2022 - Glow Plugs
Ordered two more glow plugs and got delivered the same day as the wiper motor. Ordered from Amazon, Carfar brand, hearing for the first time. Got for half the price of OE plug. HKT was not available at that moment and local retailer was selling them for almost the price of OE ones. No clue of manufacturer anywhere on the packing nor the Google. Bought it because of the good reviews on Amazon.
Carfar B07YMS5K4M - ₹476/plug
The packing itself was messed up. Came in the box for 1.3 Multijet series.
Correct vendor and Chevrolet part numbers were on the plug.
Complimentary leather keychains bundled.
Back to the FNG for install. Replaced in 30 minutes including cooling down. Charged ₹ 200 for the job.
Aria waiting engine rebuild.
He spotted early wear of front tyre and suggested rotation and alignment. Went straight to Wheel Tech. Charged ₹ 450.
OE seat covers started giving away,
Old plug was Beru. One previously replaced was Borg Warner. Dealer replaced one of the plugs during engine rebuild, thus the mix-up.
Thread Starter #384
deville_56
March 2022 - Updates
Finding perfect centre for drilling hole in boot lid for wiper motor installation.
Marked on the clamp. Used compass and measured with respect to the boltholes.
Glued in the longest bolt I had.
Extended the length with an ear swab tube. Bolted the clamp on the boot lid and found the perfect location for the hole.
Perfect.
Removed the plastic panel.
Panel made by Bright Auto Plast, a Sintex company.
Drilled up to 12 mm, the biggest bit I had. Started off with smaller bit and incremented by 2-3 mm.
Trial mount. Just shim clearance, but no fouling. A little bit of X-Y axis adjustment possible, so can be taken care during final installation. Couldn't source the rubber cover. Till then, 12-mm hole would suffice.
The other side.
Easter Egg!! Rear boot switch was built into the lock mechanism, like most American brands. I was looking for the possibilities of a rear boot switch, but couldn't find a location nor could spot on any Beat photo.
Rear number plate was stuck with 3M tapes and later with bolts, but with nut from behind. For removing the plates, had to take the boot lid trim out. To sort that out, ordered M6 rivet nuts. Link > Rivet Nuts M6 (Pack of 2)
Drilled 9-mm holes and inserted them.
Tightened with a bolt and it compressed into place. Not easy as seen on YouTube DIYs, may be due to thin sheet metal.
Number plate in. Washed off all the dirt and grim. Final install pending wiper arm purchase. Have to drill the plastic panel and without wiper arm, it would look fugly. Confused between Beat and i10 wiper arms. Liked the shape of i10 arm, but doubted fit. Kept on looking for i10s with rear wiper to take measurements. An out-of-station friend had one, and waiting for his mercy.
Had to balance tyres due to wobbling. Did just rotate and align at Wheel Tech. Took to Nayana. He flipped left and right tyres. Wheel Tech swapped front to back. Being unidirectional, had to remove the tyre from the wheel for the swap for proper direction. Total cost ₹ 600.00.
Perks of lending car.
Running around.
Thread Starter #389
deville_56
April 2022 - Rear Wiper Motor Install
Had no chance of comparing i10 wiper arm and impatience grew and spotted an el cheapo Beat assembly on Amazon. Ordered without second thought. Chevy OE arm was ₹722.00, ₹401.00 for blade and ₹106.00 for cap, making it ₹1,229.00 if I choose that route. Got the full set for less than 30%. Now lots of listings in similar price.
Generic Rear Wiper Arm with Blade - ₹ 349.00
Full set.
Made a mark on the plastic panel through the previously drilled hole.
Made a 12 mm hole.
Installed the motor
and the arm. M6 nut did the job.
Done.
Trial with 12V adapter.
In action.
Then a quick wash.
Followed by heavy downpour [cry]
Wiring is still pending. Next confusion was with original LT wiper stalk versus a standalone switch.
mayankdixit
kanpur
That's a very good workmanship you did. Congratulations for this.
In your video the wiper arm looks to be a size too large/long, almost touching the rear spoiler!! As if it's from another Chevrolet hatchback.
Maybe it's the camera angle, don't know. But still, very good workmanship, as well as execution, no doubt about that!!
