Tata Manza - Known Problems and Solutions
Madurai
I have one very very peculiar problem with My Manza. Well one fine night when I was going to take it out for night rounds I got in the car very enthusiastically in the driver's seat and the seat just reclined full back when I sat in it. I didn't pull up the recliner lever at all. Even if I rest my back with a bit of weight it goes back but while reclining it reclines fine to and fro. But with the lever down it goes back when I rest my back. Please help me.
PONDICHERRY
Tata manza engile oil outlet
I wish to change my car TATA MANZA QUADRAJET 90 engine oil & engine oil filter. I'm unable to locate the engine oil outlet. May be it is covered under the mud guard. Can anyone learned help me on locating the outlet & filter removal procedure?
PONDICHERRY
Sorry that the HTML content nor the docx format is working...that leaves you all with only text less pictures. :(
TATA Manza Quadrajet 90 AURA -- Engine Oil Replacement & Engine Oil Filter replacement
Preparation: a) Borrowed one Hydraulic jack from friend. Lift the car from front & enter under the car through the driver side. Ensure by shaking that it is firm, before I get under it. It is advised to have handbrakes on while you raise the car. Do physical verification if anything is amiss or glaringly calling for a visit to specialists.
b) Figured from owner’s manual on the engine oil requirement & specifications including make/model & specification. I’ve opted for Mobil 1 0W-40, 4 Liter pack, which costs ₹ 4,400/- (as on 07th Aug’15 MRP printed is ₹ 5,400/-) at Pondicherry (After getting some discount). There are better offers in Mobil1 0W-40 Fully synthetic engine oil for cars in 4 liter (09th Aug’15 was listing a price of just ₹3,996/-), to that extent, I bought it at 10+% more across counter. Figure 1.
We shall be using 3.5 litres of oil & it would be advised, just before action, remove 500ml of oil after measuring it using measuring jar. To Ensure that you’re having 3.5 Litres of oil in the can.
100ml is the tolerance attributed to losses, if any.
c) Had to visit TATA authorised spare part shop to buy the Engine oil filter. MRP was printed as ₹ 385/- but again after bargain, could get it at ₹ 360/-. Figure 2.
d) Five liters of Diesel to clean the engine before pouring the new engine oil (Flushing agent).
e) Card board (part of packing material) or bunch of newspapers where you can rest your back to slide under the card.
d) Tools:
i) No 6 Allen key or # 45 Torex driver bit for opening the engine oil drain plug. With ratchet wrench
ii) 27mm wrench for opening the engine oil filter.
iii) Tray to hold the old engine oil
iv) Cloths to clean the dirt & spills. Ensure you place, few old newspapers below the oil sump. Let us take all precaution to ensure that spills are as minimal.
v) Funnel to pour the Oil into the inlet.
Activity
PHASE I -- ENGINE OIL REPLACEMENT
1) Push Open the hood of the car. Open the car engine oil inlet cover & remove engine oil measure stick to ensure that no residual remain & free flow is allowed.
2) Double check if brake is in place.
3) Let the car engine be running for short time about 150 seconds with high throttle, for oil to flow out smoothly. Switch of the engine.
4) Place the jack on front side to lift the car sufficiently about 15 inches above ground. Once evenly set, ensure that you check it by shaking the car (not rocking it) to confirm its seating.
5) Place a card board or new papers, where you can just slip beneath the car. Keep necessary tools by your side.
6) Loosen the drain plug, don’t open it fully yet. You may have to use good amount of power to loosen the drain plug. Long handle tools would make things easier for you. You may add pipes to the tool to give the extension, which I did in my case.
7) Place the oil collection tray under the drain tray. With hand unscrew the drain plug slowly and let the engine plug fall in the tray with oil.
8) Wait till the oil is flushed out. Replace the drain plug & tighten it. It takes about 5-7 minutes.
9) Get out from beneath the car & pour 3.5Liters of the NEW engine oil through the inlet. Place the oil measure stick back.
PHASE II -- ENGINE OIL FILTER REPLACEMENT
10) Now, remove the rubber air duct over the engine oil filter holder.
11) Using the 27mm wrench remove the Engine filter cover, gradually using a cloth hold the filter which would be dripping with residual oil.
12) Remove the oil engine oil filter ALONG with the O ring and replace it with new. Apply some oil over the O-ring before placing it back.
13) Place it back and tighten it (Don’t use excess force, as case is of plastic)
14) Replace the aid rubber duct.
15) Remove the card board/Paper below the car. Check if there are any oil spills.
16) Remove the jack & rest the car on its wheels. Remove hand breaks & let the car be in neutral.
17) Start the car and see if all indicators are fine.
18) Have a short trip and check if there are any leaks beneath ;)
That done & you’ve the satisfaction of not being duped by service centre. Of course all the hardship gives you that extra knowledge.
Observations: Noise has reduced by few decibels & pickup has increased substantially. This on a test drive for about 10Kms.
Hi, Nice DIY.
But what to do with 5 litres of Diesel, you haven't mentioned.
Always use a socket or a ring spanner for the drain nuts. Sometimes when the nut is over-tightened during the previous oil change, an open spanner could probably rip the hexagonal head and you will have to rush to a welder or a mechanic to undo the nut and replace it with a new one.
-Ilango
PONDICHERRY
@Ilagop thanks for pointing out the lapses in sequencing the activity. Yes, 5 liters of diesel was used to flush the residual old engine oil by closing the outlet after you find all the old oil has poured off, to remove the greasy old oil along the tracks inside the crankshaft, pour the diesel in engine oil inlet. Then running engine for about 3-5 seconds & no more. Thus the old residue is re-flushed.
On tools engine oil filter (Drain plug is Torex, hence it had to be only Torex bit on 3/8 ratchet), yes, I agree with your very valid point. I did use the ring spanner, but for picture, I've use the Hex spanner (it looked right for size & location). I shall have these corrections done. Thanks Buddy.
Rajkot
TATA MANZA AC filter clean
Hi all
i am having TATA Manza Q.Jet AURA ABS.
can any one suggest me where is AC filter located in car and how to reach it without visit service center. i am the AC technician but i dont know where is filter located.
Krunal
Hi All,
Just wanted to check if you have faced this problem.
For 3-4 days petrol indicator needle was stuck to empty position even though petrol tank was full. Number of KMs before next refill showed 'ERR'. Both the problems might be related.
I own a TATA Manza Petrol (2011) model.
I will be taking my car to TASS shortly but just thought of checking in the forum first.
Cheers,
Dear All
I have just purchased a tata manza 2010 model which has run 120000 KM
Earlier i had New Ritz i fell comfortable in this car compared to Ritz even it was new
i faced water body leaking & got it replaced with a spurious part which was avauilable when leak was detected
i am not confident about its worth as it cost was Rs 1100/- compared TO THE ORIGINAL of Rs 3650
Kindly suggest shall ia replace the spurious part or shall continue driving
Sir
THE company name was GRB delhi based manufacturer the engine is running smoothly no leaks but afraid of long drives
Mechanic said no issues with long drive
