hi friends.
I'm really frustrated on the issues i'm faced. I'm going to narrate the issues, wordshop people behaviors and the response of tatamotors.
Kms crossed : 6800 Kms.
Issues:
- Suddenly the A/C is cutting off. But the air flow do continue its job with 1/4th the regular speed on fan mode (some times it look alike heater).
Ask them to check the temp sensors and thermostat.
At the same time my vehicle pulling is nothing as “0”. My vehicle not responding after some speed limit per gear. 10kms speed for 1st gear, 20kms for 2nd gear and 40kms for 3rd gear. If I try to pull in 3rd gear from 20kms speed limit, it’ll reach to 40kms speed without any pulling issue. But after that speed, the vehicle not even responding above that speed. Not even revving. If I want to move further I need to change the gear and go up. This issue happening when the A/C making issues. The instrument cluster giving NO signal of check-engine, over heat etc. I checked my engine oil and coolant. Its fine normal. I shown it to customer care manager.
Check the EGR (exhaust gas recirculation) pipe, the same happend with me but at that time the MID shown an error of Engine restriced performance. Try to change the fuel quality (use normal diesel), but try to change the pump. As this lack of pull in vehicle is also resultant of that. Aria has sensors everywhere, even a low fuel qaulity can show you check engine error.
Last in this is check the turbocharger performance as this can be very crucial for smooth pick up and performance of vehicle.
- My center locking system automatically locking and unlocking continuously when I switch off the car. Some times in parking mode. I need to lock and unlock using remote or else I need to switch on and then off the engine to make the locking system to normal. Lot of times we faced this issue. Sometimes my family with kids inside, sometimes they are inside and I’m outside. Just imagine what can I do the same happen when I met with an accident. I tried to reproduce this in front of technicians. But this kind of thing happened very rarely, i faced around 7 times in my ownership.
The same happened with me on the first day of ownership of the car. But in my case it was because of misaligned driver door. So if there is a gap in any of the door or if the door creates a gap between door and the sensor than the lock unlock mechanism will create the similar kind of problem, So better check all five doors.
- My gear lever is slipping back to neutral from 3rd, 4th and 5th gears while i cruising over uneven roads in normal speed.
Check the Clutch system as a loose clutch system can do a lot of troubles. If required ask them to change the gear lever or the entire clutch system under warranty. I just did that. If possible than you can put forward my case as example.
- The revving rhythm is changed from 50kms speed to 60kms speed using 3rd and 4th gear. In between that speed range I felt vibration like tone from engine. Just not as smooth rev.
Yes there are vibration but not speciafically to that speed range. Infact Aria interior is so refined that you will hardly notice the vibes. But at the time of hard acceleration one can feel them. There is a pipe covered in silver colour linning next to the enigne covered under the plastic cover that might be touching to the body and creating the vibrations. It happened in my case and since then no vibes are feel. Or else ask them to check the engine mountings and again Turbo charger.
- Hard vibrations felt after 110kms speed. I used to travel long trips to Chennai/Bangalore. The vibration is growing nowadays. This vibration not there before they fixed the vibration issue in the rear.
High speed vibration menans wobbling, this is mainly due to the bad wheel balancing and alignment. i also feel the same but only after shifting to Alloy wheels which are not OEM supplier.
- The reverse sensor sound indicator sometimes not working. But the display showing properly the distance to hit and stop. I faced only 2 to 3 times in my ownership.
Ask them to replce it under warranty.
- Driver seat creating sound ( not fixed properly. Some grrr, grrr uneven sound )
Same is with mine and warranty people they have taken a video of the same and now new hydraulick seat will come in a months time. under warranty.
- All doors closing sounds differ. Need to check the rubbers. The tail door making more bad sound while closing. It look a like there is no rubber support between the body and the 5th door.
Yes rear door sound is a bit more than others. no issues just try to close it smoothly.
- Interior roof lining close to rear door came off, its hanging. This was fixed at the time of delivery. But it came again.
Ask them to fix it properly. it cannot come out on its on if fitted properly.
- The interior plastic panel back-left-top not fitted properly after the rattling issue fixed before.
Its a normal job, ask some other nearby accesory shop person to fit it yourself. He will do it in a better manner.
- The same rattling sound coming again from tail gate side.
Rattling sound may be from Warning triangle, kindly remove all the stuff from the car and than try the rattling noise. Same issue had crated a bad taste in my mouth but once i came to know the reason i tied all the tools.
- Right side wiper leaving a line while wipe. Its very old issue unresolved.
Wiper can get damaged or misaligned very easily get it changed or ask them to align it.
- Some sound from roof.
Check something in over head bins first. or it may be because of loose rear roof part.
- In steering panel has lot of screwdriver depth-scratch marks. This showing how hard the workshop peoples working for me
Nothing can be done now, you should have shown the same on the time of takin gdelivery and clicked the pics. but be aware for future.
- Some uneven sound hearing from engine, when I
start the vehicle in the morning (They replaced a radiator fan few days before). The engine noise raising and downing a bit. like hhmmmhhhhmmm.
Cannot comment. Yours is 4x4 or 4x2. as in 4x4 there is a sound in cold start like kirrrrrrrr from 4x4 modulator which checks the entire system.
- Dash board storage below the chiller is not aligned perfectly. It shown bend a little. But the dealership peoples giving bad smile when i shown to them.
Ask them politely to align the cover, or ask some outside accesory shop person to do that.
- Car has alignment issue. They did alignment 3 times. The right/left pulling issue resolved. But still my inner side of front tires looking flat.
Get your vehicle chekced at a good alignment centre and ask them to check the camber values, alignment, caster values, and whell balancing. I hope you are not using the Alloy wheels.
Rest is not clear in your description as these things must be understand in person only.
Will ask other people whom i know regarding how to make complaints up higher in TML. Other wise court of the country are always open for us.
Just try to be there next time when you'll take your vehicle for attending the complaint. and do it on other service centre which has good reputed and trained employees.
ALl the best
