Some New Gadgets Found
Xiaomi launches the MIJIA Smart Camera Standard Edition priced at 99 Yuan ($14)
The Smart Camera supports remote viewing via a connected smartphone. It equally supports picture-in-picture function on mainstream Android models. The screen is pinned in the form of a small window, and the screen can be viewed anytime and anywhere without affecting other operations. It also supports multiple screens on one screen. When there are multiple cameras in the home, you can view multiple screens on the screen at the same time.
In terms of the build, the camera has a magnetic base that can be attached to metal objects such as refrigerators and other surfaces with magnetic properties. It comes with IP65 dustproof and waterproof protection making it suitable for a variety of outdoor uses.
Read:
Xiaomi Youpin crowdfunds the Deerma Sweep/Mop Integrated Mop
The Deerma Sweep/Mop-Integrated Mop is designed to be able to achieve the easy conversion of the sweeper and water spray mop, making cleaning as easy as walking. Every time you clean, your hands do not need to directly have contact with sources of contamination in order to maintain good hand hygiene. With the Deerman mop, all just need to do is push the mop and collect garbage while sweeping and with the water spray, you can disinfect the floor while mopping.
The device has a front spiral mechanical roller brush that can drive the roller brush to rotate when pushed forward, sweeping the floor dust and garbage into the dust box. There is a 230mL capacity dust box which is quite large and won’t need to be emptied frequently. It has a leak-proof and sealed design and can be opened with a light touch and the debris will fall off when it needs to be emptied such that you don’t need to touch it with your hands
Read:
Xiaomi launches the Daewoo F9 Bladeless Fan with air purification function
The device provides 9 speeds level of natural wind. This consists of 1-3 speed levels described as grassland wind spews soft air and works quietly. Speed levels 4-6 named mountain forest wind is cool and comfortable. Levels 7-9 is called ocean wind and is refreshing and dry.
The design ensures that the air from the fan is distributed indoors via convection current. It also has two HEPA filters which helps in air purification. With 30 air changes per hour, the removal rate of formaldehyde reaches 95.2%, the removal rate of TVOC volatile organic compounds is 89.7%.
Read:
Logitech Powered 3-in-1 Dock is a cool wireless charger for your phone & gadgets
The Logitech Powered 3-in-1 Dock comes in at $129.99 and the capability to wirelessly fuel an iPhone, Apple Watch, and a pair of AirPods all at once. The design includes two wireless charging zones: one stand-style pad meant for a phone and a flat pad for a pair of headphones. There is equally an extension to the right of the phone charging pad which houses a watch charger, also wireless.
Apart from the Powered 3-in-1 Dock, Logitech also released two other single device wireless charging pads. One of them is the Logitech Powered Wireless Charging Stand which is a stand-style wireless charging pad and is priced at $59.99. The last product is a flat pad dubbed Logitech Powered Wireless Charging Pad and priced at $39.99.
Read:
Montblanc MB 01 smart headphones feature 20-hour battery and cost a whopping $600
The Montblanc headphones offer both active and passive noise cancellation. The edge of the headphones features a few physical buttons on the edge of the cans to control music and toggle the noise cancellation. The buttons can also control the pass-through modes.
The headphones, however, do not support Siri yet. The only voice assistant supported for now is Google Assistant. The headphones fold towards the inside. There is a compact carrying case for easier transport.
Read:
Ambrane BT-83 speaker launched in India, priced at Rs 1,999
The cylindrical-shaped speaker comes with a sling, which makes it easy to carry around. Ambrane asserts that the textured exterior and metal rings surrounding the speaker grill brings added durability. As the Bluetooth speaker is IPX6 certified, the device can stand against dirt and water splashes.
This Ambrane speaker comes equipped with True Wireless Stereo (TWS) Technology. The brand claims that the drivers of this Bluetooth speaker bring “High bass and clear treble” with 10W output. With this speaker, one can get up to 7 hours of battery life. It features a 2,200mah battery under the hood. It even supports hands-free calling, and it has a 10m wireless range. Connectivity options include AUX input, SD Card and Bluetooth.
Read:
Nubia announces 65W GaN charger, 20000mAh power bank and several more phone accessories
Alongside the Red Magic 5G gaming smartphone announced today, Nubia also announced a bunch of phone accessories today. The lineup of accessories includes a GaN charger, two power banks, a dock for the phone, a USB cable, an official Red Magic 5G phone case and tempered glass.
Red Magic 65W GaN Charger
The charger has a foldable plug (American plug) design. There are two USB Type-C ports at the top of the charger along with a USB Type-A port.
Red Magic 55W PD Charger
Red Magic 27W PD 10000mAh Power Bank
Details:
Xiaomi launches its first 10000mAh Mi wireless Power Bank in India at Rs 2,499
Xiaomi today launched its first Mi Wireless Power Bank 10000mAh for Rs 2,499 and will be available in Black colour. It will be available on sale starting 16 March 12 noon across Mi.com, Mi Homes and Mi Studios.
Mi Wireless Power Bank comes with support for two-way 18W fast charging on both USB Type A output port and USB Type C input port. It also enables simultaneous charge on two mobile devices. Mi 10000mAH Wireless Power Bank uses high-quality lithium polymer batteries that ensure longevity and higher standard of safety.
Mi 10000mAh Wireless Power Bank features best in class 12 layers of circuit chip protection across voltage, temperature, current and electrostatic anomalies. The power bank also comes with a non-skid wireless charging surface/pad.
Read:
Sennheiser Momentum True Wireless 2 earbuds launched with noise cancellation
Sennheiser has announced the launch of its latest premium wireless headphones. Dubbed as Sennheiser Momentum True Wireless 2, it comes with a price tag of $300 (approximately Rs. 22,200). The product comes in Black colour and the white colour variants.
Sennheiser Momentum True Wireless 2 comes with active noise cancellation. There is also a Transparent Hearing mode that let users hear ambient sound at a touch of the earbuds. This feature is configurable through the iOS and Android app.
Apart from active noise cancellation, the earphones have a claimed battery life of 7 hours of playback time with up to 28 hours with the included case. On the other hand, Sennheiser Momentum True Wireless earphones were offering four hours of playback from the buds, and a total of 12 hours from the charging case.
Read:
Toreto Black wireless headphones launched in India
The major highlight of the headphone is that it automatically switches off when not in use. It also comes with control functions like play/pause/power button, calls answer button, volume button as well as aux port. The headphone also allows you to easily switch over from music to calls, letting you receive, reject and redial, with the touch of a button, and has an in-line mic.
Read:
Powerbeats 4 with 15 hours battery life launched for $149
The Powerbeats lets users to access Siri through voice commands. The connecting cable between the two earbuds moves down from the ear loop which prevents the Powerbeats 4 from coming in the way during activities like running. Since Powerbeats 4 features the same 12mm pistonic drivers that are present inside the Powerbeats Pro, it promises an audio output. There is a Lightning port on the device for charging. The retail box of the earbuds includes a USB-A to Lightning cable). The Audio Sharing feature can be used two Powerbeats 4 to the same iPhone. The said feature also lets users to connect AirPods and Powerbeats 4 to the same iPhone.
Read:
Xiaomi launches the MIJIA Desk Lamp Lite for 79 yuan (~$11)
The desktop lamp is made from high-quality ABS plastic which gives it an elegant outward appearance. The lamp features an articulated arm that can be used for adjusting the direction of the light beam. The adjustable arm can bend up to 218-degree and can be rotated 180-degrees.
The Mijia Desk Lamp Lite comes with a national standard A-level illumination while offering three blocks of comfortable and good light. The lamp equally offers protection from the damage arising from exposure of the eyes to blue light.
Read:
Soundcore by Anker launches Liberty AirX truly wireless earbuds at Rs 7,999
The recently launched truly wireless earbuds also feature Bluetooth v5.0. This ensures that it offers instant connectivity to any compatible device. Further, it also improves the range and connection stability of the product. The brand also claims that the ergonomic design of the Soundcore Liberty AirX ensures a secured fit, providing added comfort for the users on the go.
The Soundcore Liberty AirX truly wireless earbuds also feature cVc 8.0 Noise Reduction Technology. Each earbud is equipped with a microphone that optimizes the voice. Meanwhile, background noises are minimized so the conversation sounds louder and clearer on the other end. The truly wireless earbuds come engineered with what the brand calls ‘expertly tuned graphene drivers’. These apparently give the music you’re listening to, a wider soundstage. The dual-microphones bring stereo quality audio for crystal-clear conversations without external noise.
Read:
Huawei announces a Smart Insulated Flask with a Temperature Display
The new Huawei smart insulated flask features a three-layer stainless steel structure, which can insulate water for up to 24 hours. The body of the flask is IPX7 certified for water resistance and hence it can be washed safely like a normal non-smart flask.
Talking about the smart feature of the Huawei insulated flask, its lid comes with a screen attached on top of it. This tiny display shows the temperature of the water inside and also features three color prompts to describe the water’s temperature. For instance, the blue color denotes the water to be below 35° C, orange color stands for 36° – 50° C, and red represents the water to be more than 50° C. Apart from this, the flask also has a TDS reader built-in to check the quality of the water. The TDS function can be activated by long-pressing the screen and within five minutes, the result is displayed on the screen.
Read:
Oppo launches Enco M31 Wireless Neckband Earphones in India
The headset will go on sale in India on March 30. The Oppo Enco M31 earphones will be available for purchase in two color options – Black and Green. The new set of Oppo headphones offers support for Bluetooth 5.0 and LDAC to enable transmission speeds of up to 990kbps. The company claims that users will get “balanced audio across the full frequency range, with clear high frequencies, rich mid-range frequencies, and powerful low frequencies.”
Read:
