Some New Gadgets Found
Syska launches Wi-Fi enabled Rainbow Smart Strip Lights starting at Rs 3,999
Syska Accessories, a mobile accessories company has today announced the launch of the latest Wi-Fi enabled Rainbow Smart Strip Lights, under its smart home segment. The Syska Smart Strip Lights are priced at Rs 3,999 for 12W and Rs 4,999 for 25W respectively and are available at leading ecommerce marketplaces.
These lights connect to your Wi-Fi and lets you control every aspect of your lighting from your smartphone or tablet. They can be easily controlled using voice commands from Amazon Alexa and Google Assistant.
Read:
Redmi Power Bank launched in 10,000mAh and 20,000mAh capacities
The best part of Redmi Power Bank is support for dual input, which eliminates the need to carry two cables. You will be able to use a microUSB cable or a USB Type-C cable to charge the power bank. They also have dual USB output, which means you will be able to charge two devices at once. The 10,000mAh Redmi Power Bank comes with support for up to 10W fast charging. The 20,000mAh Power Bank supports up to 18W Fast Charge.
Redmi is launching its power bank in two capacities. The 10,000mAh power bank is available for Rs 799 while the 20,000mAh power bank is available for Rs 1,499.
Read:
Fingers 'Pro Wireless (PD-QC)' 10,000mAh power bank launched in India
Fingers has launched new power banks in India. The company has designed both the Fuel+ and Pro Wireless power banks to offer full-speed charging for smart devices, including laptops. The latest power bank from Fingers supports wired and wireless charging simultaneously. The 10,000mAh power bank sports an ‘A’ grade Li-Polymer battery.
The Fingers power bank comes with a wireless charging feature that can charge Qi-compatible devices while simultaneously supporting wired charging. The device features two dedicated USB-A and USB-C (Type-C) ports. The Fuel+ power bank from Fingers is a similar device, but without Wireless option.
Read:
PLAYGO BH-70 wireless headset launched for Rs 14,999
The headphones, powered on the latest family of Qualcomm processor, boasts of Bluetooth 5.0 connectivity, Apt-X codec with built-in CVC 6.0 noise cancelling microphones. They are also compatible with voice commands that can be used with Google Assistant, Amazon Alexa and Apple Siri. The headphones also have multiple modes of ANC On/OFF or even the Transparency mode which allows you to hear the ambient sound along with the adulating audio experience.
Read:
Samsung Galaxy Buds+ with 2-way speakers and 11 hours battery life announced
The AKG tuned Galaxy Buds+ truly wireless earbuds comes with 2-way tweeter and woofer speakers that promise rich treble and bass. The earbuds are equipped with as many as three microphones for crisp and clear calls. With improved Ambient Sound technology onboard, users can choose from available options like Low, Medium, High and Extra High for adjusting the level of noise cancellation. Each earbud measures 17.5 x 19.2 x 22.5mm and weighs 6.3 grams. The charging case for the Galaxy Buds has 38.8 x 70 x 26.5mm dimensions and it weighs 39.6 grams. Appearance-wise, it looks similar to the predecessor model.
Read:
Sennheiser PXC 550-II Wireless launched in India
German audio brand Sennheiser on Wednesday launched its new headphones ‘PXC 550-II’ for Rs 29,990 in India. The new headphones, available from today, are Sennheiser’s challenger to Sony WH-1000XM3 and Bose Noise Cancelling Headphones 700. These headphones are designed to offer an intuitive experience to those who travel frequently. The headphones come with adaptive noise cancellation to seamlessly adjust the suppression of the ambient noise.
Read:
Xiaomi Youpin launches the Bemcom infrared thermometer
The device needs to be pointed at the forehead and must be within a 5cm distance, in order to get a correct reading. If the working distance exceeds 5cm no reading is taken. The device has a display and a single button which is used to initiate the temperature measurement. The gadget vibrates after the temperature reading has been taken. If the temperature of the measured object is lower than 38 degrees, the machine will vibrate once. If the temperature of the measured object exceeds 38 degrees, the machine will vibrate three times, indicating that you may have a cold and fever.
Read:
Sony WH-H910N headphones launched in India for Rs 21,990
Sony has today announced the launch of its wireless Noise Cancellation headphones in India. Dubbed as WH-H910N, the wireless headphones come with a price tag of Rs 21,990 and it will be available for purchase from 14 February exclusively on Flipkart.
The WH-H910N headphones effectively cancels ambient noise around you so that your full attention is on the music. Thanks to the Dual Noise Sensor technology, more ambient sound is caught, improving your listening experience. Adaptive Sound Control allows you to listen your way by automatically changing the headphone sound settings depending on your surroundings.
Read:
Xiaomi announces Mi AIoT Router AX3600 with support for Wi-Fi 6
The Mi AIoT Router AX3600 is a flagship router powered by Qualcomm’s IPQ8071A chipset and paired with 512MB of RAM and 256MB of storage. The chip has four Cortex-A53 cores and is clocked at 1.0GHz. It also has a 1.7GHz dual-core NPU for network acceleration which is why it is marketed as a 6-core chip. Xiaomi says up to 248 devices can be connected to the router.
The router has 7 high-gain antennas. One of the antennas is an IoT device antenna, two are 2.4GHz antennas and the remaining five are 5GHz antennas. Devices can connect via 2.4GHz or 5GHz networks. Xiaomi says the AIoT antenna also supports dual-frequency and provide speeds of up to 150Mbps for IoT devices. When compared to the Mi Router AC1200, the new router is 155% faster.
Read:
Echo Flex: Now make any space smarter
Available for Rs2,999, Echo Flex is certainly an affordable way to voice control compatible smart home devices and get help from Alexa at more places in your home. Echo Flex also has a built-in USB-A port so you can easily charge your phone (7.5W) or other devices, all while using only one outlet.
The Echo Flex plugs into any standard electrical outlet, making it perfect for spaces where power cords can be a hassle, like the hallway or a bathroom. You can simply ask Alexa to control compatible smart home devices. Switch on the lights as you enter your home or turn off the AC as you leave the room, all without lifting a finger. Echo Flex works with devices such as smart lights and plugs from brands including Philips, SYSKA LED, Oakter, TP-Link and more.
Read:
Xiaomi Mi Outdoor Bluetooth Speaker launched in India for Rs 1399
Xiaomi Mi Outdoor Bluetooth Speaker is equipped with 5W power output and it comes with IPX5 rating against splashes and spills for water resistance. It is compatible with both iOS and Android devices.
The speaker works with Voice assistant which allows you to access your favourite voice assistants from your speaker with a simple touch of a button. It is equipped with a 2000mAh battery which claims to offer with up to 20 hours of battery life.
Mi Outdoor Bluetooth speaker comes with Bluetooth 5.0. The speaker has a frequency response of 20 to 20KHz. The single button can be used to answer or end a call. The built-in high sensitivity and high signal-to-noise- ratio microphone ensure clearer calls.
Read:
Toreto Air wireless headphone launched in India for Rs 2,499
The wireless earphones offer a lightweight design along with an adjustable headband. It comes with cushioned on-ear pads that are comfortable to wear. The wireless earphones come with Bluetooth 5.0 connectivity option, which allows it to connect to a smartphone or tablet. It is loaded with heavy bass stereo sound, which good listening experience with a well-balanced sound.
The controls are quite simple. It allows you to switch over from music to calls at the touch of a button with its in-line remote and microphone. This headphone can also be connected via Bluetooth and aux cable. The wireless headphones feature 300mAh battery, which it claims to deliver up to 10 hours of playback.
Read:
Anker Soundcore Icon Mini wireless speaker launched for Rs 1,999
The speaker comes with Micro-USB Port and a 3.5mm audio jack AUX input. Icon Mini comes with a strap, that strap that it can hang and play anywhere you want to.
The Anker Soundcore Icon Mini is IP67-rated for dust and water resistance, and has a sound output of 3W. The speaker also sports rubberised buttons, for water resistance. It has a battery of 900mAh which claims to offer eight hours of battery life on a full charge.
Read:
Xiaomi Youpin Launched an affordable massage chair for 3999 Yuan ($572)
The affordable massage chair operated with three individual and moving parts that massage the user sitting on it. The movements of these unique parts are synchronized and target the shoulder, neck, back and the lumbar spine of a person. Notably, its movements can be adjusted so family members of different age groups can enjoy the experience as well. The motors are capable of providing three dimensional movements that go up, down, left, right and diagonally.
Read:
Xiaomi’s IMILAB EC2 Wireless Security Camera goes global via Indiegogo
The Imilab EC2 camera keeps up with the minimalist design language Xiaomi is known for and is equally affordable. It is on offer for $99 but when it launched in China, it was offered for just 399 yuan ($56). We’ll factor custom duties and shipping cost into that, as it ships worldwide free of charge.
The Smart Camera is entirely a wireless camera and can be installed indoors and outdoors. The wireless design brings ease to installation as it doesn’t require any form of wiring. One of the stand-out features onboard is the huge 5100mAh battery which it packs. The battery can last up to 100 days on a single charge.
Read:
