Xiaomi launches the $21 MIJIA All-in-One Electric Screwdriver under crowdfunding
The MIJIA Electric screwdriver uses innovative, integrated screwless design. The body is made of high-quality engineering plastics coated using fine UV paint technology. The body also houses several contours that ensure it doesn’t slip off the hand easily. The head is also lightweight and durable. The narrowest grip of the fuselage is less than 30mm and it weighs just 185 grams.
In other respects, this screwdriver can be switched between electric mode and manual mode according to the needs. The built-in 1500mAh lithium battery can unscrew more than 180 screws when fully charged. It comes with S2 alloy steel bit and 50mm long bit, making it ideal for use in difficult places such as narrow spaces and deep holes. The device has a button which slides between L and R to determine the direction it spins.
Read:
Read:
