Re: Planning for a Trip to Leh from Trivandrum in my car
Not necessary, you can retain the same battery. Even if you upgrade your battery, your alternator won't match with it. Instead, you can go for a capacitor for your Amps; it will give more constant power to the Amps and less strain on the battery.
And when you are driving in those cold region, make sure that you are not giving full load on the battery. For exmp. you can turn off your amp and sub woofers and use only the head units, when you are driving in the night with head lights on. And when you are using the AC or Heater, it doesn't make any difference, because the compressor is driven by the engine, and you need power only to engage the clutch, and for the heater, the radiator water is used; and in both cases the blower runs and requires power. All these parameters are applicable only when you are driving there, just to keep the battery at its full power.
I would strongly recommend to have a co-driver with you, in case of any emergency, he will be a great help to you. Taking adventures and challenges in life is very good, but at the same time one can not close his eyes against some realities and risks.
I already have a ICE system which has multiple amplifiers and subwoofers. My car has powerful headlights, fog lamps and power windows.
Should i upgrade the battery before i commence the trip?
Sankar
Sankar
