Re: Ownership Review: Polo 1.2 TDI Comfortline (Diesel)
I had to pay for the coolant but rest everything was covered under warranty. Also I spoke to the mechanic over the phone he told that the main problem was fuel pump, the fuel needs to always be pressurised to reach the engine, when the car is standing for long time like 10 hours + the pressure drops, so it takes longer (long cranking ) to start the car.
There was a loose coupling/leak in the pipe connecting the fuel pump. Once this is fixed all the other things are also fixed. No more check oil warnings or anything else.
One question to the forum though, does the check engine light is on when the car is not running. Meaning once you insert the key and rotate it but not start the car, all the lights flash first , but after some time (like a sec or two) all the lights go off except for check engine light, battery and parking indicator, does this happens to everyone? The engine warning light goes off once you start the car though.
Good to know that you got the car polo_owner. Please ask about the problem from mechanic as it would help polo owners on the forum.
I hop everything is covered under warranty
