Dear Dr. Mudhan,
Planning to get alloy wheels. What are the things to be considered while buying one? Running on stock 175 good year Tyre. I wanted to replace the stock wheel with aftermarket alloy. For now I will be using it with stock 175 Tyre. but later i have plan to shift to 195. what spec would be ideal? please give some of your opinion. i am confused with width, offset, hub dia etc.
This is what I have switched to (when my OEM MRF tyres were at 17K kms):
Wheels: HRS Model H 713 HyperSilver
Size: 6.5J x 15"
PCD (Pitch Circle Diameter): 100 (same as stock wheels)
Offset/ET*: 40 (same as stock wheels)
(or *Einpresstiefe in German or how far away is the center of the width from outside mounting wall - or how far is the wheel going stick out from the hub)
Alloy Wheels Explained - Rimstyle.com
http://www.alloywheelsindia.com/product1/search/558/6/15/18/40/h_713.htm
Tyres: Pirelli P1 Cinturato
Size: 195/60R 15 V88
Tyre Of The Month
The overall diameter of the new 195 tyre is 5.8 mm bigger than the original 175 and ride height is increased by 3mm. These are negligible changes (lesser than the 3% permitted) to make much difference in the speedometer or odometer indications (eg. when speedo reads speeds of 50. 100 and 160 kmph, the actual speeds will be 50, 101 and 141.5 kmph).
A note of warning though: When you eventually upgrade tyres (say, something like Pirelli P1, Michelin ST 3 or Bridgestone Potenza MY-01) belive me, your driving experience will be transformed to a level where you will be wondering why did I stay with those OEM tyres as long as I did, I should have changed tyres when I got the alloys.
Hope you find this information useful.
