re: My Modified Maruti 800.
Hi
Thanks for the suggestion friend... Will try to fix it as you said... I think mine is not a branded one and thats why am facing the problem. My dad's driver took my car to fix those lamps and he said he fixed it for Rs.450/-. As you said brands works better.
Shankar, fog lamps have to be of good quality. Cheap ones simply waste a lot of power and do not give the required brightness. You can get Hella, Lightforce, Neolite etc. You can fix any light on your car, provided you run the car for a fair enough duration during daytime/without turning on the fogs - so the battery gets replenished. The higher the wattage, the battery will get drained faster. Good fogs come with a wiring kit as well, that includes wires of the required thickness a relay and probably a switch.
A lot depends on how you align the fogs as well. Make sure the mounting brackets of your fogs are not loose. Hella provides mounting brackets with most of their lamps. Use them to mount the lights properly. I can comfortably drive around with just the Hella MicroDE aux lamps - they're just 35W. When cruising I use the low beams and use High beams only to flash and hit back at high-beam morons.
If you are ready to spend close to 12k, you can go HID. For that, buy an Amritas P8 HID kit (available in Bangalore), which is a direct replacement for the bulbs in your fogs. Be warned that the reflector of your fogs might not be designed for taking in HIDs and hence they MIGHT cause a lot of unwanted glare. But they are extremely bright. You should focus them properly.
