My Love: Maruti Alto LX 2007 Ownership Review
Goa
No. I am not facing air loss frequently. I get the pressures checked every 2000 kms (which is at around once every 1.5 months) and I lose around 5-10 PSI in half an year, from my past experience. In the new Ritz, I first got the pressures lowered to the recommended level (since the pressure was ~40 PSI from the showroom!) and get it checked every 2000 kms (around once every two months). I have lost ~1-2 PSI in the 9 months of ownership and around 9k kms.
Are you sure ???
Do you check at same place everytime?
The sudden loss and marginally 1-2 psi for 2 months makes me feel that gauges are wrong since its now nitrogen gas filled(99% nitrogen)...
Thread Starter #302
Hoshiarpur, punjab
It should work. Just try again with starting your car and wait for some time to engine worm up. Then try engage first gear without revving. If you succeed , go to your mechanic and tell him the problem.
Experts please gave your suggestions.
Thread Starter #303
Hoshiarpur, punjab
Hi guys!
I am going to upgrade my ICE setup again. The only weak section in my setup is the front in-dash speakers . Alto has strictly 4˝ option available in dashboard [frustration]. Current speakers are Pioneer TS G414 30w RMS.
They are ok not bad, but not as good as rear speakers . Pioneer TS A6962E in rear parcel tray are awesome and these easily overtake front speakers while playing at higher volume.
After some research on internet , found Polk Audio DB401 with 45w RMS are best in the category . So ordered the same on snapdeal.com
Impatiently waiting for the delivery .[:D]
Thread Starter #306
Hoshiarpur, punjab
Hi guys! Have got my car serviced today. It was a regular 5k kms service .
Some parts changed in front suspension .
Cost:-
Engine oil 3Ltr Shell Helix HX3 20w 50 rs.850
Oil filter rs. 85
Suspension bush kit rs. 280
Suspension arms rs. 900
Welding minor rs. 100
Labour rs. 500
Total rs. 2715
Thread Starter #307
Hoshiarpur, punjab
One more thing. From so many days the evil inside me was forcing me to install powerful horns on car. Today when on an accessory shop when i saw Roots Magasonic horns, the evil woke up again. Tried hard to stop myself but failed. Spent Rs. 2900 for set of horns, relay, higher gauge wiring, special mountings and a toggle switch .
Spent higher on horns than service [frustration]
But boy these Horns can wake the deads [evil]
Some pics while servicing
Veerey,
What's the cost of the horns you told at home?[;)] Just be cautious, not to use those horns excessively, may invite a Challan! In Punjab, the traffic norms are really strict.
Post a video if possible!
Thread Starter #309
Hoshiarpur, punjab
[clown] Didn't tell anything about horns yet. After some days i will tell them the horns costed rs. 500 [lol]
These horns will be used only for highways and for some deaf idiots. Simply T T horn is there for normal use.
Hi Saroya,
Didn't see a post of a new DIY from you since long. Can you please post a DIY for removal/installation of the front bumper.
N/A
I bought the foot pump tyre inflator, but there seems to be no manual.
How to use this, is the gauge provided reliable. If i want to keep 30 psi but if it exceeds to 34 how to reduce the psi?
Thread Starter #313
Hoshiarpur, punjab
Hi! Sorry for late reply. It is easy to use just connect it to your tyre valve and pump it with your foot. Usually gauges provided are not reliable, so you have to purchase separate gauge to check and maintain required pressure.
Panchkula
Hi there I wanted to know about any shops in chandigarh if u know any that could install a projector hid unit in my alto k10 silver 2012 model at an affordable price??
NCR
Simple. Remove the inflator pump and press the centre of nozzle of the valve (in tyre) with nails or something similar. The air inside will come out. Refill to the desired pressure from the pump again.
