yes, both these are plug and play and are brighter. thou the stock ones are not that bad either. using fog lights also helps in such cases.
strange! i suggest you check the tyre pressure since it seems your tyres are carrying more air than required. coz with more psi, the car flies.
it will increase over usage. You will find a considerable difference after 1000 kms thou the true FE will be seen after 5000kms.
I will go to some petrol bunk and have them do 30/27 PSI (front/back).
I think H! recomnds 29/26 PSI front/rear .
Also, im not 2 worried abt the FE, just that others posting 20km/litre makes me envious
