Today I went to the garage for radiator flushing and cleaning of AC condenser and evaporator.
All work was DIY so I don't have any pics to upload.
First I flushed the radiator properly using lots of water. And then filled the radiator with
a 20:80 mixture of acid and water and kept it for half n hour. When I drained the acidic
water, it had lots and lots of dirt and green particles. Again the radiator was flushed
using normal water. The fins were cleaned using soapy water and a toothbrush.
For cleaning the water chamber of the engine, only pressurized water was used.
The overflow reservoir and fan blades were cleaned using luke warm soapy water. The fan blades turned white from grey and the humming sound of the radiator fan has vanished.
The AC condenser and evaporator fins were cleaned using pressure water and then with warm soapy water. I had sealed the inlet and outlet pipes using rubber sealer caps while cleaning with water. Later the AC components were cleaned using pressurized air.
I also checked the spark plugs, it was a little pinkish in color and had no carbon deposits.
