I agree with you,100kmph is quite fast and at times even dangerous on our roads. I was interested in knowing its capabilities at such speeds mainly for those "emergency" overtaking maneuvers where a powerful engine will help. Anyway, a remap should take care of it :) Also, can you post your impression on the in-gear acceleration timings ? ACI says the Duster 85 is much faster in the 20-80 and 40-100 mark
40-100 range I guess there shouldn't be much difference.
Also one need to keep the Ecosport in Turbo range to get maximum acceleration, if
you upshift the gears at low speeds too quickly then you will feel that the car is less powerful.
Keep the car in turbo range, and then upshift the gears at appropriate speeds to get good acceleration.
Overtaking is not at all problem, until unless you are trying to overtake a similar powered or high powered car.
Till this time I didn't need to go over 2000 RPM, except for steep inclines. I felt that the turbo kicks in from 1200 RPM.
