@Rajivluvstheblues:
Sirji count me in for the Pajero Sport MiVEC. Blame the IR for this interest and especially the way he puts his views about this upcoming Mitsubishi. I have been a bit aware of the vehicle and if my calculations about the testing to launching ets are right then we will get to see it before one complete year on our roads. Along with the coming Fortuner maybe!
BTW once again my choice of the two, the Fortuner will also come with a new design and a 2.4 + 2.8l engine combo. Is expected to get a better suspension and better ride and handling. But I am sure that Toyota will price is equally high as much are changes
. Adding more to the voes is the Endy 3.2!! Outright power is still something that is more pleasing than many other factors.
@IR Sir:
I agree on the point of engine braking and I hope you also agree on the part that it's fine only in the higher gears. The lower gears in these big hearted diesels has a very jerkiness in engine braking and one has to use clutch + brake while the vehicle is in lower gears.
Rest I never recommend the sudden and quick downshifting during hard braking! BTW you get enough time to do that in emergency situations? This practice not only pushes engine to the rev limiter but can also cause the driving wheels to get slightly locked up while the smaller gear is reached and you will never like to have it done while giving a steering input IMO.
The practice I follow is:
Engine braking:
On highway when I know I have to stop at a certain distance. Leave the gas pedal and keep downshifting wits revs felling till 3rd cog and then press the clutch+brake .
In city the engine braking is fine even till 2nd cog. The first one is too jerky.
During emergency:
It's always engine brake + brake without downshifting and both hands on wheel if I am at 100+.
It's clutch+brake if I am at 60 or below; even if I hit something. This really helps because engine is not bogged down and one can downshift and fly in a moment.
As sharpshooter mentioned, the PS AT gearbox is not very happy downshifting quickly, even under engine braking. It tries its best to hold to the higher gear for as much as possible; maybe this is the reasons they gave the pedal shifters because their gearbox really annoys at times. Heck, I guess I was talking to you over this just a couple of days back. Although the PS has got everything nearly right but the gearbox needs to be worked on, it seems to be more biased towards FE and performance thing is driver centric with those pedal shifters.
@Anbarasan:
Sirji is your vehicle stationary when you make this transition? It is a bit strange you know.
This one may sound weird to some A/T owners but I recommend you to follow this practice once and let us know if the problem still persists:
Bring the vehicle to complete halt and disengage the reverse. Wait for a second or two and engage the drive mode. Now check if the 'jatka' is still there.
@Kartik:
Congrats for acquiring the devil's ride. Once own this and nothing else will make you feel the same in the price bracket.
