Did you purchase this service manual?
And thanks once again for the red chilli idea. I had sprinkled in our Etios on 24th Dec evening and no rat was caught in 3 days. One problem was that it gets blown away while driving. As there was no rat poop found, so I think they are gone!
Yes I have purchased total of four manuals for Swift and Dzire, first part No 1 contains VOL 1 and VOL 2 which covers petrol and diesel. Other service manuals are supplementary manuals, after upgrading some parts they release supplementary manuals. Great information with detailed step by step procedures with pictures. I have ordered Baleno service manual too. In my case red chilli powder is not blown off even at high speeds. Try coarse chilli poweder like brand Ashirvad.
-suryputhra
Service manual covers entire car like engine rebuilding, ECM, wiring, suspension, brakes AC, ABS, air bags, etc etc.
My experience with so called underbody coatings
Usually underbody coatings are thick weigh more than normal paint. They are coarse too. Their thermal elongation and contraction properties differ with normal automotive paint. It has been observed that over the time they become dry and brittle, forms microscopic cracks, when they crack or fade away they also takes original paint microscopically. Because of above mentioned physical and chemical properties differences, rust is formed under the coating where the crack happened or where the original paint lost, and this cannot be seen with naked eye until significant rust formation. This appears like small bubbles under the black coloured under chassis paint.
There are two types of under chassis coatings available today. 1. Bitumen(asphalt and petroleum based). This type will not dry off so easily but they are not resistant to diesel wash and other road chemicals, their thermal properties same as above mentioned. They fade away and take the base paint which is less weight than this and micro mm thickness and do the above mentioned harm. 2. This type is asphalt free and diesel wash resistant, like 3M under chassis coatings, but over the time it become very brittle and do the more harm.
I used spray under chassis with 20% diesel with 80% new engine oil using spray gun. I did not see any rust past 17 years in my old cars. With this method you can actually see what is happening in car under chassis over the time and will not blind you until some damaged occurred like in the case of under chassis coating. I am following all of my family cars the same procedure.
-suryaputhra
