Hi Taigers
My swift 2007 zxi has a peculiar problem the airbag light is on continuously. Previously the vehicle was diagnosed with a alternator replacement , A Throttle body cleaning, A battery terminal replacement ( initially all odo & speedo lights would fluctuate or blink at will )
please advise
Please check battery terminals are secure and having good contact, with no loss contacts,
you replace alternator for what reason?
Odo light fluctuating means loose connection beside the instrument console.
Even this may lead to abs light ,
Mostly that light glows if ecu finds any problem in airbag electronics.
Please take to service as soon as possible ,drive safe
If you are replacing the battery the thumb rule is Negative terminal should be disconnected first and while connecting back it should be the last to connect. There is a reason for this, if you remove the positive first the wrench you are using may make contact with car body, or else it may get ground through your body in some cases. This will result in a massive short circuit and frying of equipments.
@tusharbhai Sorry if we confused you, don't think too much and remove the negative terminal (black cap or no cap) from any side. Watch that video, it will help.
@Stingray: Do you really think the fellow members don't know disconnecting either of the terminals will cut the circuit!.
I just shared my thoughts buddy, did not mean that way
