Re: Suzuki's New Premium Hatchback Baleno Now Launched!
Not really sure how many km or litres. But the tank is 40l, and its 5 segments on the fuel gauge, so each segment is 8 litres. So the light comes on at 8 litres
Ameyam
Gurgaon
Hello All,
I have a query.
Can anyone please tell me if Delta version of baleno have security function S3 and S4 i.e. pre-warning sensitivity of the shock sensor and full blast warning sensitivity.
I have a Delta petrol version and someone has hit the car when it was parked out of the house.
And I did hear the tuk-tuk sound only once or twice. When I checked security indication system using selector knobs, I did not get options for S3 and S4.
Please reply.
Thanks
Abhinav
na
Hello All,
I have a query.
Please reply.
Thanks
Abhinav
Hi Abhinav,
not sure about Delta, but Zeta has the function. I myself tried to hit on the bonnet and first time it makes that tik tik sound and second time if you again hit or pull the handle it will alarm loudly.
Try that by urself and check if its working fine. to stop the alarm you can press the unlock button from Key Fob.
Amritsar
Hello All,
I have a query.
Please reply.
Thanks
Abhinav
I've Delta Petrol myself, i can confirm that it has S3 and S4 functions. Firstly it did not show anything but i accidentally Reset the system and now it is shown.
Make sure you/ve S1 enabled ( SEL sign indicate it's ENABLED)
Alternatively, get out of the car, lock and unlock it and see if it get displayed. Good luck!
Hi Abhinav,
I couldnt get the function to work at all. Can you tell me how you set it?
Ameyam
Gurgaon
As per car manual:
If the security system “S1” is in the disabled
state, the shock sensor “S2”, prewarning
sensitivity “S3” and full blast
warning sensitivity “S4” cannot be set
up.
But i get only S2 when S1 is enabled.
I will try to reset everything by going through the manual on next weekend.
na
Ameyam
You need to select the antitheft option and select enable also do same thing with set sensors option and keep it on neutral mode. Let me know if it doesn't work will click pic from my MID and post it so you will kW what to select. Initially even i couldn't get it but after playing with it a bit its working nw..
Actually i did that- enabled the sensor, then selected the sensitivity. Question is, what setting did you put them at? My intent is to deter the night time smokers who practically sit on the quarter panels but dont want it to go on blaring
Ameyam
na
Ameyam
hmm i need to check the settings, frankly speaking i also set it up accidently while playing with it. will check this weekend properly and let you know again. Car has been given for water wash after that long drive and parked at my relatives house as its close to the service station.
Can somebody give a online link for a baleno body cover. I'm searching in online but didn't find a suitable one yet. If somebody purchased and using it, please give a link. Thanks.
