Glad your issues solved, as I told you earlier shoddy job of brake caliper pins. Now they have cleaned and greased properly, problem solved. As you observed greasing top and bottom of the pads are caliper pins. You said they have washed pads that clears the brake dust created by earlier pad irregularities, cleaning the pads with emery paper. Let them replace the suspected part for the noise issue. How about leaning to one side. Regarding Tyre rotation check images. Post alignment report.
