Gave the car to tge ASC for checking yesterday
Headlight dimming- was ablr to demonstrate it to them. He tried on another Baleno which did not dim. But that car was cold, so idle was high. Much later they came back saying the dimming of headlights under load was happening for all cars
Alternator check- the checked & informed it was ok. However my battery was showing low specific gravity. I hadmt used my car since sunday, so they weren't sure if that is the reason. They put my battery under charging & gave the car with a service battery. With my original battery the car gad stalled thrice & browned out 6 times in the morning 6~7km drive to the ASC but with the service battery and headlights ON in the evening it did neither. The will inform regarding my battery today
Clutch setting- they said the did something but the notchiness is still there. Surprisingly, the notch is not felt in 1st gear if the engine is off
Steering- they said they checked all the steering parts & did a decent test run at 60~70 & found no problems. However the road the did the test om is gently curved, so not sure what they checked. So i can only confirm when i take the car onti the expressway
To conclude, they did almost nothing
Ameyam
Ameyam
