Update for Baleno ZETA owners :
DIY REAR VIEW CAMERA INSTALLATION
Disclaimer : NO IMAPACT ON WARRANTY if exact Tapping Connections are used.
This DIY is only for ZETA owners. Apologies for poor quality of pictures and less number of picture for STEP 4. Full credits to TAI.
THE DIY IS FULLY REVERSIBLE if the BLACK CAP in rear chrome strip is replaced by New one. Part No. 39977M68P00
As this DIY was done before 45 days, NO ISSUES OR RATTLES ARE FOUND.
Tools :
a. Drilling Machine
b. Star Screw Driver
c. Tool post or Bit Spanner Size : 10
d. Cutting Players
Components :
a. Xenos(or any branded) 16.5mm Flush type camera. CAUTION CAUTION : 16.5mm diameter only. COST : Rs1200
b. Suitable display(Mirror or Dashboard mount-I Have Used MGA) COST : Depends on Type of display
c. Tapping connectors. COST : Rs 5 each
d. Wires. COST : Rs 15 per meter
Step 1 : Remove the rear hatch and use the Grove circled in the picture for removing the Trim panel.
There are 12 clips to be removed. Remove them in Anticlockwise direction.
Step 2 : There are Two 10 sized nuts beneath the crome strip at circled places. Remove them gently.
Step 3 : Remove two Star screws circled in the picture which holds the black cap to the crome strip.
Step 4 : Mark diagonal cross lines on the face of black cap to obtain its centre.
Hold the cap firmly using Players and drill the hole using Drill bit provided with the camera.
Insert the camera gently. CAUTION : Dont firmly install camera till Step-8 is completed.
Step 5-1,2,3 : Route the wires as shown in the Picture
Step 6 : Remove two 10 Sized bolts holding the Left side tail Light and gently pull the Assembly outwards.
Use Tapping connectors to provide power for Camera From Reversing Light.
TIP(iff necessary, not preferred) : If you are finding short of connectors, just TAP +ve terminal and connect -ve terminal of camera to a Bolt connected to car Body.
Step 7 : Connect a suitable monitor at a required place in Dashboard or mirror. Connect Camera to Display.
Get power for Display at the same place in Step - 6 as it doesnot require tapping again.
Step 8 : Start the vehicle and engage Reverse Gear. Rotate camera till you get the exact view from camera.
Now push the camera and fix it firmly. Take help of a friend to align camera.
Step 9 :
a. Fix the Black cap to chrome strip.
b. Fix the Chrome strip to Rear hatch. CAUTION CAUTION : These 10 Sized nuts should be tightened gently!! Never Overtighten it!!
c. Fix the rear tail light assembly.
d. Fix the Black Trim Panel in Clockwise direction.
ALL SUGGESTIONS ARE WELCOME.
I would be glad to help if you need any other pictures or procedure.
CHEERS !!
