Well,today took a good 31 kms long test drive of the Aria 4X4 and here is my experience(I DID IT AT THE SUVs EXCLUSIVE SHOWROOM HERE,SO FOUND THREE ARIAS TOO):
First of all,the car had 21000 kms on the odo but it was still as good as new and after that took a short test drive with an owner too in his Aria pleasure for about 4 kms and talked to him too(as I believe only what I have seen),his Aria had covered about 17300 kms and it was also driving like its new,with no signs of ageing.
Then met one more customer there,he had some small problems with the car,but all were sorted out and now he was also happy with his car and he had also covered slightly more than 15000 kms in his Aria..
Firstly I agree with Raj at some points,which are as follows:-
There was an another Aria too parked in the workshop and had some problems,the problems in that Aria and the one of a customer were as follows:-
1):The GPS and USB port failure,even the TD car was having this(Its GPS was not working,but USB was).
2):While the car which was parked had its clutch burned/failed and it had just 3007 kms on odo.
Enquired about this,then came to know that this car was driven by a novice who had the habit of driving with his foot on clutch from the very first day and it was the first car to have this problem..
Still,I don't believe it as the clutch plates/clutch is not that weak thing that it will go off by any novice acts,so it may be a problem/mistake by the Tata's either QC or there is some problem that clutch is not that reliable and cannot take too much abuse.
But these brake failure,steering failure,gearbox breakdown issues etc etc were simply proven nothing more than craps there.
When I told the sales guy about the rumors that Aria is not at all reliable,he said "Sir,what proof can I give you"?
I:If you can show me the copies of service records of some cars...
He:Sir,I'll have to ask the SA.
He called the SA and a humble guy with a smiling face came in..
Sales guy:Can you show some service records and answer some questions by sir?
SA:Yes sir,just come and sit,I have copies of nine records and complain lists,I can show them to you.
I was very pleased by this(this was one of the best services I have ever got) and went on..
Then he showed me nine records and here are my observations:
1)None of the car ever had brake failure.
2)None of the car ever had a gearbox or suspension problems.
3)None of the car had any issue with steering.
4)Only one car had an issue with the clutch.
5)4 cars had got their reversing camera assembly changed,after that no complains.
6)7 had this GPS system problem.
7)2 had the USB system problem.
REST HALF OF THE ISSUES SIMPLY WERE PROVED CRAP..NOTHING ELSE..
@Raj:
Can you get me the registration number and chassis number of this Aria which was owned by the first customer,the one who had 16 problems.I showed the list to SA and he laughed and asked these two things.Saying "Bhaisahab badnaam karne ko toh main apko bhi g** keh dun(Sir,even I can declare you a g** for worsening your name)"
I hope this customer got them repaired at Tata A.S.S only,else this will not be there in record with Tata.Also can you PM me the name of the service center?(SA asked this too saying "Sir I am doing this job for 7 years and am amazed to read this,once an Indica customer complained and my job went under the sword").
Then I test drove the Aria..and now I am ready to bet on the fact that
ARIA IS JUST OVERPRICED,ELSE IT IS REALLY BETTER THAN THIS XUV THING...
Last but most important:
THIS NEW SHOWROOM WAS OPENED JUST 7 MONTHS BACK,BUT IT HAS GAINED A REPUTATION OF BEING THE BEST TATA SERVICE CENTER HERE..So,this may also make some significant differences.
