Guys i need help regarding verna's clutch issue it does'nt slot in the gates properly and it is followed with very irritating sound {Grrrr}
as i had googled it earlier and found that it can be solved by changing cluth plate,pressure plate and some bearing and some also said to change the sleeve cylinder i for have changed the above today in front of myself and again while coming back home once the car get's heated {if u drive the car in a lot of traffic}i faced the similar problem .
I am totally blank know what to do ?
![Anger [anger] [anger]](https://www.theautomotiveindia.com/forums/images/smilies/Anger.gif)
BTW how much did it cost for you to change the cluth plate,pressure plate bearing and slave cylinder
