Ask them for your wheel alignment report. If they have done it then they should provide it. I did not know what is done in "Idle Speed Actuator Cleaning" and "CLIP"
![Roll Eyes [roll] [roll]](https://www.theautomotiveindia.com/forums/images/smilies/Roll.gif)
My santro's ac used to trip at idle , it only worked after a continuous light tap on the accelerator. Mechanic opened and cleaned this part and i don't have any problems.
Clip must be some consumable item.
@ auto - no offence but don't you check the items and bill amount while shopping ? If there's any item missing but the bill has mentioned it won't you ask the shopkeeper about the same ?
Same goes for car service. Advisor will always list the work needed to be done on your car , get your signature and then only starts the work. At that time you should ask him about the significance of listed items.
If you don't he will mention unnecessary items in the next service also.
The balancing mentioned in the bill is the labor to open the tyres and using their balancing machine. Weights are the actual thing which balance the tyre so that they don't wobble at high speeds. Don't mention about the wieghts but do asl him for the report. If he gives you some accuse demand a refund. Most probably they didn't do anything. Do ask him about the 4th and 5th item.
