Re: Hyundai Fluidic Verna VTVT SX (O) 2 Years and 30,000 Kms
Hi.. Thanks for the inputs. Just to add, the driving style of mine is very orthodox, I always make it a point to not drive above the 3k rpm mark and even the gear shifting is quite smooth.
One drawback here in Delhi is the TRAFIC, that's the worst one.
Will it be useful to go to the service centre ?
Aside "allhyundaicars" : I guess you are from Delhi, do you know any service centre which have the Sxo Crome gear knob for vtvt sx?
Hi there
if your car is giving 10 kmpl in delhi traffic than it is absolutely fine, below that is an issue to look into, kindly follow the following steps:
1.) Get your car serviced
2.) Clean or replace the Air Filter,
3.) Check coolant and other consumables items of car
4.) Clean all the AC filters, inside and outside radiator grills
5.) Try to fill from different fuel pump or may be brand like from HPCL to IOCL or BPCL
6.) Check cold tyre air pressure and bring it to 32 psi
After doing all this than on a sunday fine morning take it for a milage run test, like fill the fuel upto its brim and take the car for ride of around 50-60 kms on clean road like Gurgaon or Yamuna expressway. After the run fill the tank from the same pump and dispensing unit upto the brim and check the milage.
Also check it with MID.
Chrome Gear Knob: At the time of purchasing the car I demanded the same thing from my dealer i.e. Himgiri Gurgoan and they obliged it by changing it with Chrome one. Its a very easy job done in 15 minutes. Go to Himgiri or any other service centre and ask them for the part and get the person to change it and pay to him the labour amount.
The part cost was around 1400 - 1600 INR and labour would be around rs 100.
