Got Tata Sierra - Turbo!
ilango[speed thirst];94096 said:
Update.
Just tried tightening the belt more .
voila that works .
now i start and drive at once like hmmm all car hehehe
No creeching sound .. finally happy!!
Great to know that Ilango.
That picture above is an epic. Two Tata cars of different generations parked together. Will look even better with Aria instead of Manza.
Bhubaneswar
Hi Ilango,
First of all many many congrats from me for your new car. Now both of us can exchange our ideas. I know i am very poor in that.
Well i see the belt problem what you have mentioned. Which i was facing till now what i have posted in my thread.
As per the specification of the Vehicle the belt number is:
6PK1640I well my is a Standard Sierra not Turbo.
I hope this helps u.
Well do update about your sierra.
My Temperature meter is not working at all.
Thanks
Thread Starter #79
Hi Ilango,
Thanks
thanks mate , !!
Hope the belt problem for you is wrong placement of ac manifold , as you said in the other thread
yeah the ac and fan drive belts are 6pk belt both in std and turbo!
for me the other belt , that drives the power steering and the alternator.
was giving trouble.
we thought the belt is already tight and noise was due to some other reason.
but just gave a little more tightness and the belt noise stopped.
now its fine - lets see for how many day!! hehe
Temp meter need to be working in any car , as it helps us to drive caustiously.
Hope the same reason made you engine back compression .
Bhubaneswar
ilango[speed thirst];94417 said:
thanks mate , !!
was giving trouble.
Hi
Is there any relation with the temperature meter and the back compression.
I thought its normal wear and tear of engine as the vehicle is almost 16 years old. As well at the time of purchase which is 1 year ago from now there was around 2,60,000 KM on the Odo.
So, i thought as the engine has run so much that's why its having Back compression. Is there a way to check back compression. I mean how we know a engine is having Back compression?
Thanks
Thread Starter #83
Normal wear and tear may be the cause. 2.60 from new without a overhaul in middle is a good number.
what i mean was , if you constantly run on high temperature , like without noticing the temp needle or , non working of temp needle , it will have its effect causing ceasing of engine at the end
Bhubaneswar
Could you give some symptoms of a back compression engine.
Brilliant snaps. They’re straight from the heart of a passionate Sierra owner and it clearly shows. Great job, Vikram and welcome to The Automotive India. :smile:
Nice work there too Vikram. The pics talk about the passion and zeal for Sierra[:)]
Thanks all!!
And, Yes! I am so passionate about Sierra; since my 5th class!
It's been a wait of almost 13 years to POSSESS the Beast!
