Update: Went for a TD with Metro Ford, St. Marks Road on Saturday. The Metro Ford Driver / Technician drove the car with me, and the route taken was Mekhri Circle to Devanahalli and back in Bellary Road. Seems, this is the only route they do TD for FE check.
Note: St. Marks Road to Mekhri Circle and back isn't counted in the TD, which is actually having more traffic than the route we took and may be that's the reason too.
Filled the Tank up to the mouth (until the fuel is visible) at Mekhri Circle and drove in the route mentioned. Being it a Saturday about 11 AM, the traffic was minimal and crossed the signals and got the highway pretty early than otherwise. As I was noticing his driving style, he was upshifting sooner than normal, without considering the RPM readings or load with the engine. That proves that he wanted to reach the top most gear the earliest as possible. The speed was between 60 - 70 all the time. He was shutting the engine at signals without even waiting for minimal idle time. When I asked him about the same, he said that doesn't matter for such short drives. However, I pointed it to him that the Turbo was running and it's isn't good. Moreover, it doesn't make any difference for switching off and on with in 30 secs than idling.
We were back to the same Petrol Pump and filled the tank to the same level from same nozzle. The overall drive was 51 KMs and it drank 2.7 Lts which delivers the FE to 18.89. Surprising? I was not, rather not happy either. For this kind of drive, TDCi should easily have delivered 20+ or at least 20. However, Metro Ford is quite happy with this figure and said this is the max you would get.
I politely declined their gratification for many reasons. Firstly, the route was almost a Highway Drive with minimal city driving conditions. So 18.89 for a Highway Drive at a speed of 60 with 2 people on board isn't that impressive. Though it isn't too low to complain, but not so great to be gratified either. My whole point was, if this is the maximum efficiency for this kind of drive, what about our B-to-B Bangalore City driving condition?
I asked the Customer Relationship Manager to ignore the driving conditions and think of other possible factors that could affect the FE, which he wasn't ready to, rather possibly, he couldn't. So, he handed me back to Metro Ford, Lingarajapuram and I went there again... Do customer have a choice here? That's the best part in our country.
Location Change - Metro Ford, Lingarajapuram, where this 40K service was done last week and I reported on the Low FE. (I was asked to go to St. Marks Road as the FE test is done only from there, which was informed to me just a day earlier). I met with Branch Manager and Service Manager and same stories and dialogues. They were giving the same answers of the CRM of St. Marks Road and the dialogues continues...
Then I show them my excel sheet for the last 2 years, which covered the details of each fill with FE and other factors captured. They both look at each other and then me... Do you maintain one like this?
Yes, I do... From day one till the past hour.
I said, I am reporting something just not without any background or data. Firstly, I am an active member in TAI (got a chance to advertise TAI) where we have better experts. Secondly, I have captured the data and calculated the FE of every fill, not just missed even one nor have filled it partially anytime. I am a sedate driver maintaining the optimal RPM as far as possible. So, it's just not a vague claim that I filled for 200 bucks and Fuel Needle won't just move up... All I am asking is, 1) I am not convinced with this TD for FE check, even if I do, not about the Figure achieved under this condition. 2) Just think more than the driving conditions, is there anything else which could affect the FE? Recently serviced, new Air Filter, New Tyres, what else?
Also, the DTE works weird always. When you tank up, it would show some figure say 600 and will reduce by 1:1 or 1:2 up till the tank is close to 3/4th. When it reaches that level, both DTE and Fuel Meter won't just move a bit low until next 50 - 100 KMs depending on the driving conditions. After which, it will reduce drastically as 1:2 on average. Earlier I thought it's normal and that's when the system recalculates the DTE based on driving pattern, however, both of them denied that it shouldn't work that way... They thought about various factors which could affect the FE or this issue. They agreed to check the Clutch play manually and fuel injectors flow using the system. We connected to the system and checked the Fuel Injectors flow and many other functions and found to be just fine. Though I was present there and looking at the screen couldn't figure out much as they were quite technical. He checked the clutch play manually and said it's quite good too.
He asked me to check on the DTE when would it stop next time and report back so that they can see it that time. I too agreed as I thought they would understand it better when it's demonstrated directly than explaining hypothetically. So need to go back, very soon...
BTW, they said, we can also change the Float in the Tank if that may be the issue. However, not sure if that's the issue or that's going to solve it. So what's the point? In any which ways, DTE is just an approximation, what about the Low FE issue? Isn't that the whole issue we are talking about? Good question, no answer...
Enjoy This: The Service Manager said the maximum DTE range is between 575 - 620 and I was like WHAT??? I said, there are people who have got 700 to 800 range and same have got 900+ too. I remember seeing one pic of 925 in Figo Facebook page for which he laughed and said not possible at all as the meter is limited to 620. If it's showing any value more than that, then it's a faulty Float. I LOL saying, I myself used to get 700+ in general earlier and surprised him back. He called up someone from Ford and found himself wrong right then & there...
