I want to ask a que for a long time & now this is right place.. hopefully.
Also like to know for LXI/LDI trim how may Keyhole is there other than ignition at Steering ?
Yes in the base variant there is 2 keyholes are available other than ignition at steering in driver side and co-driver side.
rear side you have manually lock inside and then proceed with the other 2 front doors.
But by the autocop keyless entry in driver side actuator there is feature if the remote battery fails r key-less damage in this case if your lock the drive side door all the other doors will be auto locked by the main trigger in the driver side door actuator gun.
If battery disconnected for LDI/LXI trim of Ritz, Is it possible to lock the car via both side Door Lock when the car is in stock condition (before installing anything) ?
when battery terminal is disconnected only thing is it will reset meter time to 12:00 that's it no other impact to car electronic system as this is base variant.
