No. Diamond glaze does not contain polish it.
It has little cleaning ability which means scratches or swirls are cleaned (Not removed). It should be fine if the paint doesn't require deep cleaning. For paint finish that is not been detailed past several years then polish is required.
Ok. I was actually selecting products without having a proper understanding of those. Now i sort of understand that in detailing world, the labels of products and words can be more confusing and you got to understand what does it do.
Yes, don't go by the product title but by its product description and you'll understand what it does.
Polish has a corrective ability to some extent. Again, polish can be non-abrasive or abrasive. As I understand Pure polish are non-abrasive.
Many detailing experts say, start from least aggressive product. i.e Polish, Scratch remover, compound and finally sandpaper
Polish is indeed non-abrasive and last step for paint correction, then you'ed proceed to filling and protection products.
Poorboys Pro Polish 2 is something like a compound because it is capable of removing 1500-2000 grit sanding marks! However, it is for professionals and a machine is required.
Poorboys Professional Polish is least aggressive and micro scratches can be removed, atleast with a machine.
Between these two, you may find scratch remover which can remove micro to medium scratches.
Like I said above, Poorboys Pro Polish 2 is for heavy paint corrections and you don't need it.
Poorboys Professional Polish is fine but only if the paint needs it. This thing should remove paint contamination that clay couldn't not and also make the paint (especially clear coat) shine or strip it if buffed long (e.g using cutting pad)
4. Apply glaze - My question here is, whether applying glaze is required after polish, since polish would have corrected the mild scratches / swirl marks, or, will glaze helps in covering / hiding the swirl marks which are not corrected by polish.
Yes, those that polish couldn't remove, will be filled by glaze.
5. Sealant - Poorboys Ex-P sealant which does not contain wax
6. Spray wax
Like I said in previous post, If you like to Poorboys Ex-P then you have to get a pure wax. Lastly you can use spray wax or leave it.
Or if you like to use EX then finish with spray wax only.
Spray wax is for quick detailing but for full detailing you need a pure wax.
This is fine but you will notice less durability compared to pure sealant.
4. Can glaze be applied after sealant, If yes then this step would be applying glaze
No, you cannot. Either the glaze won't bond over sealant or will strip off soon.
I don't know or understand whether Poorboys Polish With Sealant contains wax. If it does then you can apply spray wax.
