The 3.0L EcoDiesel badge identifies the engine at a glance.
3.55 Rear Axle Ratio
A numerically lower axle ratio results in lower engine rpm and better fuel economy. A numerically higher ratio improves acceleration, climbing grades, carrying loads or pulling a trailer.
800-Amp Maintenance Free Battery
Electronically Controlled Throttle
GVW Rating - 6,950 Pounds
When properly equipped. See dealer and check owner's manual for details.
Maximum Duty Engine Cooling
Next Generation Engine Controller
The next-generation engine controller is a powertrain controller consolidating both engine and automatic transmission controllers into one component. It provides better coordination between engine and transmission functions for excellent performance and efficiency.
