68. Chevrolet Corvette 2017
- Displacement 6.2L/376
- Fuel System Direct Injection
- SAE Net Horsepower @ RPM 455 @ 6000
- SAE Net Torque @ RPM 460 @ 4600
- Suspension Type - Front Short/Long Arm
- Suspension Type - Rear Short/Long Arm
- Suspension Type - Front (Cont.) Transverse Leaf Spring
- Suspension Type - Rear (Cont.) Transverse Leaf Spring
- Steering Type Pwr Rack & Pinion
- Engine, 6.2L (376 ci) V8 DI (455 hp [339.3 kW] @ 6000 rpm, 460 lb-ft of torque [621.0 N-m] @ 4600 rpm)
- Transmission, 7-speed manual with Active Rev Matching
- Rear axle, 3.42 ratio, limited slip
- Rear wheel drive
- Frame, aluminum, structure
- Suspension, 4-wheel independent
- Steering, power, speed-sensitive rack-and-pinion, variable ratio
- Brakes, 4-wheel antilock, 4-wheel disc
- Calipers, Dark Gray Metallic-painted
- Exhaust, aluminized stainless-steel with 3" polished stainless-steel tips
