Coverage: AutoMoto '17
Thread Starter #31
Kuwait, KL03
McLaren MSO 688 HS Sold at AutoMoto 2017, in Kuwait.
Only 25 McLaren MSO 688 - cars are produced in the life cycle. One is already sold in the expo ( the middle one- Mango Yellow color). News attached.
Thread Starter #32
Kuwait, KL03
24. McLaren MSO 688 HS
[This vehicle is SOLD.]
  • Top speed 327 kph / 203 mph
  • 0-100 kph, 0-60 mph, 2.8 seconds
  • Power& torque 688 bhp / 506 kW, 700 Nm @ 0 rpm
  • bhp / weight 536 bhp per tonne
  • Displacement V8 3.8 litre / 3799 cc
  • Weight 1283 kg / 2829 lbs
Thread Starter #33
Kuwait, KL03
25. McLaren MSO 570S
  • Engine Type, TWIN TURBO MPFI
  • Engine Size, 3.8L
  • Cylinders, TURBO V8
  • Max. Torque, 600Nm @ 5000rpm
  • Max. Power, 419kW @ 7500rpm
  • Pwr:Wgt Ratio, 311.8W/kg
  • Bore & Stroke, 93x69.9mm
Thread Starter #34
Kuwait, KL03
26. McLaren MSO 570GT
  • MAXIMUM SPEED 328KPH (204MPH)
  • 0-100KPH (62MPH) 3.4s
  • 0-200KPH (124MPH) 9.8s
  • MAXIMUM POWER 570PS (562BHP)
  • MAXIMUM TORQUE 600NM (443LBFT)
  • ENGINE CAPACITY 3,799CC
  • TYPE V8
  • TECHNOLOGY TWIN-TURBO
Thread Starter #36
Kuwait, KL03
28. Jeep WRANGLER
  • 3.6-Liter V6 24-Valve VVT Engine
  • 5-Speed Automatic Transmission
  • 4:1 Rock-Trac® Part-Time 4WD System
  • Next Generation Dana® 30 Solid Front Axle
  • Next Generation Dana® 44 Heavy Duty Front Axle
  • Next Generation Dana® 44 Heavy Duty Rear Axle
  • Power Rack-and-Pinion Steering
Thread Starter #37
Kuwait, KL03
29. Volkswagen Touareg 2017
  • Sport w/Technology 3.6L V6 Touareg, from $49,495
  • The Sport w/Technology includes--
  • Premium touchscreen navigation
  • 4MOTION® all-wheel-drive system
  • Hands-free Easy Open liftgate
Thread Starter #38
Kuwait, KL03
30. Alfa ROMEO
  • Engine Size 1368cc
  • Cylinders 4
  • Valves 16
  • Fuel Type Petrol
  • Transmission Manual
  • Gearbox 6 Speed
  • Drivetrain Front wheel drive
  • Power 147 bhp
  • Top Speed 130 mph
  • 0-60 mph 7.9 secs
  • Torque 250 Nm, 184 ft-lb
  • CO2 Emissions 127 g/km
  • Euro Emissions Standard 6
  • Miles Per Tank 673 miles
Thread Starter #39
Kuwait, KL03
31.Dodge Charger
  • ALL-WHEEL DRIVE
  • LED RACETRACK TAILLAMP
  • 6.4-Liter V8 SRT® HEMI® MDS Engine
  • AutoStick® Automatic Transmission
  • Driver / Passenger Power 4-Way Lumbar Adjust
  • Front Passenger Seat Belt Alert
  • Power Front Driver and Passenger Seats
  • Rear 60 / 40 Folding Seat
Thread Starter #40
Kuwait, KL03
32. Honda CIVIC
  • 1.5-litre, 16-valve, Direct Injection, DOHC, turbocharged, 4-cylinder
  • Horsepower @ rpm 174 @ 6000
  • Torque (lb.-ft. @ rpm) 162 @ 1700-5500
  • Displacement (cc) 1498
  • Emissions rating Tier 3 Bin 125
  • Bore and stroke (mm) 73 x 89.5
  • Compression ratio 10.6:1
Thread Starter #41
Kuwait, KL03
33. BMW X6 M
  • 567 HORSEPOWER
  • X6 M 4.4-liter, 32-valve M TwinPower Turbo V-8 engine
  • M-tuned xDrive all-wheel-drive system, Dynamic Stability Control (DSC), including Brake Fade Compensation, Start-off Assistant, Brake Drying, and Brake Stand-by features, with Dynamic Traction Control (DTC), and Dynamic Brake Control
  • M Drive with M Dynamic Mode Hill Descent Control (HDC)
  • M chassis and suspension system M Compound 4-wheel ventilated anti-lock disc brakes (ABS) with cross-drilled rotors and blue-painted calipers
  • M-tuned electric power steering with M Servotronic Dynamic Damper Control with rear-axle air suspension
  • Dynamic Perforamance Control and Active Roll Stabilization
Thread Starter #42
Kuwait, KL03
34. Acura NSX 2017
  • Sport Hybrid SH-AWD® power unit
  • Front wheels: mechanically independent from rear power unit components, two electric motors (Twin Motor Unit); rear wheels: twin-turbocharged V6 gasoline engine with one Direct Drive Motor and 9-speed DCT
  • Maximum total system power-573 hp
  • Approx. top speed -307 km/h
  • Type -Twin-turbocharged DOHC V6
  • Layout-Longitudinally mid-mounted
  • Horsepower-500 hp @ 6500-7500 rpm
  • Torque-406 lb.-ft. @ 2000-6000 rpm
  • Displacement-3493 cc
  • Bore and stroke-91.4 mm x 88.9 mm
  • Compression ratio-10.0:1
  • Maximum engine speed-7500 rpm
  • Power output per liter-143 hp/liter
  • Valve train-24 valve, IN/EX VTC, chain-driven camshafts
Thread Starter #43
Kuwait, KL03
35. Acura TLX 2017
  • Engine- 2.4-litre, 16-valve, Direct Injection DOHC, i-VTEC® 4-cylinder
  • Horsepower -206 hp @ 6800 rpm
  • Torque -182 lb.-ft. @ 4500 rpm
  • Displacement -2356 cc
  • Bore and stroke -87 x 99 mm
  • Emissions -Tier 2 Bin 5
  • Compression ratio -11.6:1
  • 8-speed dual-clutch transmission with Sequential SportShift® paddle shifters
  • Drive-by-Wire Throttle System™
  • Front-wheel drive
Thread Starter #44
Kuwait, KL03
36. Audi Q7
  • Audi pre sense® city and basic
  • Xenon plus headlights with LED daytime running lights
  • Panoramic sunroof with sunshade, power tilt and slide features
  • Leather seating surfaces
  • Power folding 3rd row
  • 4 doors, 7 passengers, all-wheel drive; 20/25 mpg city/hwy
  • 2.0-liter turbocharged 4-cylinder engine; 252 hp, 273 lb-ft; 8-speed automatic transmission
  • Engine TypeTurbocharged and intercooled inline-4
  • Displacement2.0 L/121
  • Fuel DeliveryDirect injection
  • Horsepower @ RPM252 @ 5000
  • Torque @ RPM273 @ 1600
  • DrivetrainAll Wheel Drive
  • Trans Order Code
  • Transmission Type8-speed automatic
Thread Starter #45
Kuwait, KL03
37. Audi RS 7 Quattro
  • 4.0-liter turbocharged TFSI® V8 engine with 560 hp and 516 lb-ft
  • quattro® sport differential and dynamic steering
  • Audi adaptive air suspension (with RS model-specific tuning)
  • Valcona leather seats with contrast honeycomb stitching (with RS model designation)
  • MMI® navigation plus with voice control system and MMI® touch with handwriting-recognition technology1
  • Engine TypeTwin-turbocharged and intercooled V-8
  • Displacement4.0 L/244
  • Horsepower @ RPM560 @ 5700
  • Torque @ RPM516 @ 1750
  • Trans Order Code
